Thread Number: 39310
Tweaked water levels in Speed Queen |
Post# 582578   3/15/2012 at 08:43 (4,423 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Well today I did a measure of the tweaked water levels in the Speed Queen.
She is filling 7 gallons now!! She shows water through the holes in the tub at 1 gallon, --very efficient. TO compare: The 1958 Duomatic uses: Low- 6 gallons on fill High - 8 gallons on fill. BUT The sump of the DUO takes a whopping 3 gallons before any water shows in the holes in the tub!! So the effective working water is minus 3 gallons. The SQ effective water is minus 1 gallon. The Duo does between 9-15 pounds effective wash with 5 gallons! The SQ can do up to 18 pounds effective wash with 6 gallons. 15/5=3 3 pounds/gallon in the DUO for wash. 18/6=3! 3 pounds / gallon in the SQ--with my factory tweak! So the SQ is washing just like the DUO now. YAY! I never knew how much water the sump held in the DUO before! So Rosalie's is at the same concentration in each machine but you can tweak 3 more pounds of clothes out of the SQ because of its efficient use of water!! The Speed Queen is a more efficient machine, there have been improvements in 60 years. |
Post# 582662 , Reply# 2   3/15/2012 at 13:25 (4,423 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 582676 , Reply# 3   3/15/2012 at 14:31 (4,423 days old) by Pulsator (Saint Joseph, MI)   |   | |
