Thread Number: 39532
Amana TL needs new bearings-- any tips? |
Post# 586047 , Reply# 1   3/31/2012 at 06:14 (4,380 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 586226 , Reply# 2   3/31/2012 at 23:16 (4,379 days old) by MattL (Flushing, MI)   |   | |
Thanks, I was afraid of that. I seem to recall it was leaking so I bet the seal is bad and that took out the bearing.
Any tips of replacing the seal? |
Post# 586329 , Reply# 3   4/1/2012 at 09:19 (4,379 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This like all washer repairs is doable and given your great success fixing the FL washers bearings I am sure that you can do it. This machine is basically the same overall as the SQ TL washers that we are selling now. The big difference in the SQs is a much better designed main seal design and the more stable porcelain covered steel outer tub that holds the water seal.
The biggest problem in doing this repair is getting the machine dissembled, often the bolts that hold the wash basket in get really stuck and you end up destroying and replacing several other parts by the time you get it apart and back together. And unfortunately like the FL washers when the bearings go bad it is usually not cost effective to pay someone to make this repair, so 90% of these, Amanas, FL washers in general and SQs TLers will be scrapped when the main seal fails and ruins the bearings. SQs FL washers are one of the few FL machines that are fairly easy to replace the main bearings and seals on, so they are much more repairable. |
