Thread Number: 39593
Check-up on the 65 Lady Kenmore washer |
Post# 586524   4/1/2012 at 22:08 (4,405 days old) by turquoisedude (.)   |   | |
Post# 586526 , Reply# 1   4/1/2012 at 22:11 (4,405 days old) by turquoisedude (.)   |   | |
Well, it doesn't sound good, what can I say??
That squealing noise scares the hell out of me, so I stopped the washer right away... CLICK HERE TO GO TO turquoisedude's LINK |
Post# 586527 , Reply# 2   4/1/2012 at 22:13 (4,405 days old) by turquoisedude (.)   |   | |
Post# 586529 , Reply# 3   4/1/2012 at 22:14 (4,405 days old) by turquoisedude (.)   |   | |
Post# 586536 , Reply# 4   4/1/2012 at 22:49 (4,405 days old) by LLMaytag (Southern California)   |   | |
Post# 586537 , Reply# 5   4/1/2012 at 22:50 (4,405 days old) by pdub (Portland, Oregon)   |   | |
Paul,
I'm far from a Kenmore expert but do have 1 WP and 1 LK. The first thought that came to mind when I heard the noise on the video was that the pump may be siezed. It was too short of a clip to really tell but it could be the belt dragging against the siezed pully. I know you know your stuff and will have this figured out in no time. Maybe try turning everything by hand underneath and see if things are moving freely? Best of Luck and I'm sure this will be simple. Patrick |
Post# 586549 , Reply# 6   4/2/2012 at 00:10 (4,405 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Paul,
Whatever is binding up, didn't start out that way in the first second or so of the motor running. I can clearly hear the basket drive pulling wobbling a little bit on the spin tube. I doubt the pump is causing this, usually a locked pump will just cause the belt to slip over the pulley. It can slow things down, and heat up the belt, but I don't recall seeing any that brought the whole machine to its knees. I have a feeling that either the gearcase is locking up (or the shifting of the cam bars is causing a gear-case freeze) or the basket drive pulley, which is already making noise, has done so. Best way to find out is to remove the belt from the pulleys, and see if they turn freely. If not engaged in spin, the basket drive pulley should free-wheel with very little effort from a finger. You should be able to grab the gearcase pulley and freely spin that too. If something is locking up during a function shift at the wig-wag, you'll be able to see it and feel it too when turning the gearcase pulley. I'm sure it will work out, and that you can find the current issue easily! Gordon |
Post# 586557 , Reply# 7   4/2/2012 at 01:32 (4,404 days old) by pdub (Portland, Oregon)   |   | |
Post# 586729 , Reply# 9   4/2/2012 at 19:14 (4,404 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Gordon and Mark you guys have good ears, it is differently a dry basket pulley bearing I have heard that sound a 100 times. I would not spray WD-40 on it, instead a permanent fix is to lay the washer on its side and drip turbine oil at the bottom edge of the pulley while turning it. This is a permanent fix over 90% of the time unless the pulley bearing is very worn. The loose wires need to be reconnected fortunately they are all well labeled. |
Post# 586732 , Reply# 10   4/2/2012 at 19:19 (4,404 days old) by stan (Napa CA)   |   | |
Post# 586782 , Reply# 11   4/2/2012 at 22:06 (4,404 days old) by bendixmark (Winchester Mass)   |   | |
WD40 is often needed to dissolve the sticky crud on the bearing before oil is applied.This applies to all seized up bearings. |
Post# 586799 , Reply# 12   4/2/2012 at 23:47 (4,404 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 586875 , Reply# 13   4/3/2012 at 10:55 (4,403 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
John,
I have heard this noise a few times, but the worst was fairly recently. I had put back together my 1975 Kenmore 70, which I had scavenged from the back lot of a used appliance store. It was missing the console, motor, transmission, and pump, but they had left the basket drive attached to the basket and just let it all hang there. It was about 1995 or so when I hauled that washer home, but 2009 when I put it back together. I sourced the proper pulleys for the motor, gearcase and pump, and when all put back together, I expected the usual KM/WP quiet pak near silent machine. NOT!!! That basket drive was either the reason the machine was scrapped in the first place, OR, it dried out while sitting for 14 years. The thing sounded like an anxious water buffalo in heat! Just like Paul's machine actually. I took the basket drive all apart, and experimented with cleaning and re-lubricating the pulley. It is tight on the spin tube and not wobbly, but it still is not right. I was going to swap a new drive into the machine....so you think I should try your suggestion and simply goober some more turbine oil into the lower flange area of the spin tube? G |
Post# 586881 , Reply# 14   4/3/2012 at 11:45 (4,403 days old) by turquoisedude (.)   |   | |
Patrick - it's funny, but my first thought was the water pump, too - come to think of, I believe the person I bought it from said something about thinking the water pump was messeed up...
Gordon - I tried to manually rotate the pulley to the right of the transmission housing - it turned smoothly for a bit, then seemed to drag, but I was able to get it going again with some persuasion....
John- I will have to call you for more info on how to grease the basket pulley! I am just dying to get this Lady washing again... |
