Thread Number: 39686
Some Easter DW eye candy. |
Post# 587844   4/8/2012 at 02:29 (4,398 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 587845 , Reply# 1   4/8/2012 at 02:30 (4,398 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 587846 , Reply# 2   4/8/2012 at 02:32 (4,398 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 587848 , Reply# 3   4/8/2012 at 02:33 (4,398 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 587849 , Reply# 4   4/8/2012 at 02:36 (4,398 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 587850 , Reply# 5   4/8/2012 at 02:38 (4,398 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 587871 , Reply# 6   4/8/2012 at 07:11 (4,398 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 587873 , Reply# 7   4/8/2012 at 07:21 (4,398 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 587874 , Reply# 8   4/8/2012 at 07:26 (4,398 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Does it have the revolving wash & rinse arms above the dishes also? |
Post# 587895 , Reply# 9   4/8/2012 at 10:45 (4,397 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 587903 , Reply# 10   4/8/2012 at 11:18 (4,397 days old) by westingman123 ()   |   | |
Does Grandpa need adopted? *LOL* |
Post# 587948 , Reply# 11   4/8/2012 at 15:34 (4,397 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Yes there is an Upper Arm with Double Jets on the end but only 2 more jets on the Upper.
The Upper Rinse System is a Curved Pipe with 4 Stationary Fixed Spray Nozzles. The Later Machines switched to a Revolving Upper Rinse Arm. Because the Wash Water is recirculated it's best to Spray the Rack off before sliding it in. But I can tell you, if you don't Pre Rinse the rack, the results are spotless. |
Post# 587955 , Reply# 12   4/8/2012 at 16:25 (4,397 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
I agree it is important to spray off the dishes in this type of machine. I do this very thouroughly. If you look in the scrap trays you will see the machine is still clean and I had done about 40 racks since the last water change. No but I wish it was. It is in the Prior Lake Mn. VFW. It has been there for over 40 years. |
Post# 587986 , Reply# 13   4/8/2012 at 21:08 (4,397 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 588008 , Reply# 14   4/9/2012 at 00:49 (4,397 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Gets used for: Monday burger nite, Taco Tuesdays, Wednesday bar menu, Thursday Chix strip nite, Friday full menu(I run him for this), Steak fry(many of which I work the broiler)every 2nd and 4th Sat. of the month, 8 Pancake breakfasts a year, and many catered functions. This DW is still a daily driver. After 42 years he's only on his 3'rd motor, 4th set of heater coils, 2nd booster heater and original everything else.
I would bet this dishwasher has done millions of racks over his life. He just passed an inspection from the Minnesota Department of Health so he will do thousands more. I doubt many dishwashers (commercial or domestic) could carry on the legacy that ths one has and clean as well with as few repairs. LONG LIVE VINTAGE HOBARTS! Nick WK78 |
Post# 588009 , Reply# 15   4/9/2012 at 00:58 (4,397 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
You are correct about the upper wash/rinse system in this machine. The Ni-resist wash arms continued through the AM-ll series before being replaced with the Ball Bearing hub SS arms of the AM-12 and 14. All single rack door type machines up through the AM-12 used some varient the 4 nozzle rinse system. The revolving full size upper rinse arm did not appear on Hobart door type dishwashers until the AM-14 was introduced in 1983.
Nick WK78 |
Post# 588151 , Reply# 17   4/9/2012 at 16:11 (4,396 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
