Thread Number: 39770
SQ / Huebsch Dispensers |
Post# 588965 , Reply# 2   4/13/2012 at 06:16 (4,394 days old) by mrb627 (Buford, GA)   |   | |
The dispenser on the SQ FL machine is its only fault, IMO.
Because the drawer empties to the back of the machine, when liquid detergent is added, it runs immediately out into the outer shell of the dispenser drawer. Coating the drawer housing underneath. Then you close the drawer and the detergent never gets rinsed cleanly away from that surface. I find it best to add detergent to the drum directly and skip the drawer altogether. Speed Queen needs to come up with a liquid detergent insert for this drawer. Malcolm |
Post# 588967 , Reply# 3   4/13/2012 at 06:25 (4,394 days old) by teknikleespekng ()   |   | |
I dont use liquid that often, but yes my current machine does that too. I can hear the liquid running out and down. I wonder if it would be prudent then to get the tool just to have it on hand? |
Post# 589200 , Reply# 5   4/14/2012 at 03:10 (4,393 days old) by qualin (Canada)   |   | |
Tek, To answer your question, I've owned this machine for about 3 months now. We've been using powdered Kirkland detergent and liquid Tide (Both Non-HE) in the machine, we've both been experiencing great washing results. |
Post# 589219 , Reply# 6   4/14/2012 at 07:17 (4,393 days old) by logixx (Germany)   |   | |
Does it still flush the bleach at the start of the main wash or has that been corrected so that the chlorine does not interfere with enzyme detergents? On the front loaders I used, the drawer could simply be pulled out. Probably because other students at the dorm abused the drawers enough to break the mechanism. Then again, it was a good thing because I could wash the drawer before I used the washer as they were super filthy.
Alex |
Post# 589286 , Reply# 7   4/14/2012 at 12:07 (4,393 days old) by Pulsator (Saint Joseph, MI)   |   | |
Hmmmmm... By the looks of things it seems the bleach dispenser is a bit larger than the fabric softener dispenser. I wonder how the dispenser works on this machine? Does it have separate fill solenoids for each compartment or is there some kind of diverter? If it has separate solenoids, I bet I could switch the hoses for the bleach and softener! |
