Thread Number: 39789
Let's Talk: Pumps |
Post# 589160 , Reply# 5   4/13/2012 at 22:49 (4,366 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 1083024 , Reply# 7   7/29/2020 at 22:38 (1,337 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Lets not forget about the 1995 and later GE washers. Also, what type of pumps did whirlpool dishwashers use? Did they use centrifugal or turbine pumps? |
Post# 1083025 , Reply# 8   7/29/2020 at 22:43 (1,337 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I've wanted to talk about pumps for sometime. |
Post# 1083483 , Reply# 10   8/1/2020 at 21:46 (1,334 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I noticed later tall tub dishwashers by whirlpool starting in 2000 had a dual pump system. What style of pump setup is this? |
Post# 1083486 , Reply# 11   8/1/2020 at 22:00 (1,334 days old) by chetlaham (United States)   |   | |
Post# 1083489 , Reply# 12   8/1/2020 at 22:36 (1,334 days old) by cfz2882 (Belle Fourche,SD)   |   | |
there are some animations on Youtube showing vortex pumps-if I can find one of my early plastic GE vortex pumps i'll add some pics :) |
Post# 1083574 , Reply# 13   8/2/2020 at 10:46 (1,333 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I believe the hydrowaves had vortex pumps. Please correct me if I'm wrong. |
Post# 1083576 , Reply# 14   8/2/2020 at 10:52 (1,333 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Some of whirlpool's dishwasher pumps are vertically mounted, while others are horizontally mounted. Do the whirlpool tall tubs have centrifugal or turbine pumps? This includes the point voyager and wash right designs. |
Post# 1083592 , Reply# 15   8/2/2020 at 13:50 (1,333 days old) by cfz2882 (Belle Fourche,SD)   |   | |
on my Hydrowave,2008,the pump is the same PM centrifugal as the later transmission plastic GEs-mounting and fittings are the same for the early and late pumps,i could install the earlier vortex punp on my Hydrowave if I wanted to :) |
Post# 1083802 , Reply# 16   8/4/2020 at 01:21 (1,332 days old) by abcomatic (Bradford, Illinois)   |   | |
The pump in my Hoover portable spindrier machine. I don't know but the pump in this washer is awful. The washer section and spin tub do their thing, but the pump won't pump for some reason so I can't use the machine. What do I do to remedy this? Thanks |
Post# 1083855 , Reply# 17   8/4/2020 at 12:15 (1,331 days old) by Mickeyd (Hamburg NY)   |   | |
I took one apart many years ago, and pump's housing and impeller reminded me immediately of a blender blade. They seize up from mineral and detergent residue. Just a few few years back, when a newer machine's pump failed, I simply rerouted the drain hose from the back of the machine to the bottom, under the wheels, and now drain by gravity.
The nice thing about the 'Oovah is that the water stays in the wash tub even with the hose on the floor, as long as your valve switch is still working. The spinner drain remains open but that's okay. Mine is in the basement so the hose drains right into the gutter then the sump. In my world, that's A FIX, (smile), not to mention a smashing success :'D |
