Thread Number: 39916
Check out this little PINK agitator... |
Post# 591058   4/20/2012 at 15:15 (4,386 days old) by danmantn (Tennessee)   |   | |
Post# 591077 , Reply# 1   4/20/2012 at 17:27 (4,385 days old) by Lebron (Minnesota)   |   | |
Post# 591081 , Reply# 2   4/20/2012 at 18:29 (4,385 days old) by brastemp (Brazil)   |   | |
This is a semi automatic washing Brazilian. Semi automatic agitator not very common here, most have impeller. The name of this washer is Bellissima by Mueller. CLICK HERE TO GO TO brastemp's LINK |
Post# 591108 , Reply# 3   4/20/2012 at 20:57 (4,385 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Eduardo, does this really mean zig-zag or is it a way of saying back and forth? The spinners are cute. Thanks |
Post# 591181 , Reply# 5   4/21/2012 at 08:05 (4,385 days old) by Tomturbomatic (Beltsville, MD)   |   | |
According to the website, these are to be paired with the spinners they sell. They do not appear to be twinnies. |
Post# 591355 , Reply# 6   4/22/2012 at 13:15 (4,384 days old) by brastemp (Brazil)   |   | |
Hi Tom, zig-zag makes reference to the agitation system that for back and forth. Mueller does not manufacture twin-tub, separate spinner only. |
Post# 591462 , Reply# 8   4/22/2012 at 21:59 (4,383 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
The Vision version is NLA but they still have the semi-automatic version. CLICK HERE TO GO TO thomasortega's LINK |
Post# 591463 , Reply# 9   4/22/2012 at 22:02 (4,383 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
This is the fiberglass version of the first Mueller washing machine (Mueller Pioneira). CLICK HERE TO GO TO thomasortega's LINK |
Post# 591519 , Reply# 10   4/23/2012 at 02:46 (4,383 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
they look really interesting machines, would love to see the black washer dryer in action.
Their use of video animation is excellent, I wish a few more big names would take on the idea!! The large agitator (blue) looks like a copy of the Servis Speed Queen Simplicity machine, with the high vanes and about the same speed and turn or Ziga Zaga as they call it!! |
Post# 591525 , Reply# 11   4/23/2012 at 04:06 (4,383 days old) by qualin (Canada)   |   | |
I would consider purchasing one of these machines as something I could use for small loads. |
Post# 591558 , Reply# 13   4/23/2012 at 08:41 (4,383 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Mueller Superpop It comes in a box smaller than the machine... CLICK HERE TO GO TO thomasortega's LINK |
Post# 591559 , Reply# 14   4/23/2012 at 08:43 (4,383 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
This machine has an storge cabinet and can be used as a laundry sink. CLICK HERE TO GO TO thomasortega's LINK |
Post# 591561 , Reply# 15   4/23/2012 at 09:00 (4,383 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Their biggest washer. CLICK HERE TO GO TO thomasortega's LINK |
Post# 591791 , Reply# 19   4/24/2012 at 11:37 (4,382 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Isn't Danby products made in China, Korea or any other xing ling country? |
Post# 591943 , Reply# 21   4/25/2012 at 01:11 (4,381 days old) by qualin (Canada)   |   | |
To the best of my knowledge, Danby is an American company. Now, as to the origin of their products, I'm not entirely sure. |
Post# 591960 , Reply# 22   4/25/2012 at 03:45 (4,381 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Would be interesting to see how both are made and what the differences are,like you say with a lower spin speed the machines dont have to be beefed up as much so plastic components can be used more....
Thomas, can you explain expand more on this statement " problem with the fragile drum coupling was also considered and solved." Heres a link to my MonoTub Titan pics... CLICK HERE TO GO TO chestermikeuk's LINK This post was last edited 04/25/2012 at 07:55 |
Post# 592006 , Reply# 24   4/25/2012 at 08:22 (4,381 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hi Thomas, link now working, hadnt heard that about the coupling, I dont think it was about for the longeivity to prove that, the tub only locks in one position, if not you simply cant shut the outer door, and it has a simple but very functional switch which activates the door locking mechinism and a light on the fascia which comes on when the tub is inserted and the door locked successfully, then the wash will commence.
It was well known that "Which" consumer group tested these machines , the word on the street is that they tested it with a max load of denims (7kg = 22 pairs) if thats true no-one would do that and it simply broke the model being tested...again it does bring up the issue of sustainable drum volume and ratio of load capacity! I too think this machine has some unique features, wide access door, simply computer programming corresponding to all washable laundry codes (ITCL standards), Power Spray action which really does soak and power spray the clothes continually throughout the tub, heater in sump requiring less water per washload.....am not sure about the unique drum, but one thing I found is that if you do carry the drum around you load it very differently for a front loader than a traditional one, ie stacked like a TL then turn it on its side....tended not to ball things up as much on larger bedding etc.. Heres the pic of the poly drum connector, dont forget this drum is simply the holder of clothes, this fits like a glove in the stainless steel inner drum sleeve which rotates like a traditional fl- this has the main bearing...and then the SS drum sits inside the outer poly tub....so three drums really, not just a removable two drum affair!! You could say the load baring is shared across all components, not just the brass connector at the back of the poly drum, alas volume of sales and longeivity will not tell us now!! I also think if it had come to market sooner with all kinks sorted (dont forget some of the first models produced that we now covet of Vintage washers had horrendous issues and consequences for many companies we now come to adore) that it might have been a different story, it was competing against Whirlpool Dreamspace / Duet and the Dyson contrarotator - and looked what happened to that!! CLICK HERE TO GO TO chestermikeuk's LINK |
Post# 592137 , Reply# 26   4/25/2012 at 19:16 (4,380 days old) by JaredH ()   |   | |
the action reminds me of an SQ..that's probably how that Muller does it as well. |
