Thread Number: 40003
hoover electron dryer |
Post# 592344 , Reply# 1   4/26/2012 at 13:22 (4,375 days old) by electron1100 (England)   |   | |
Post# 592345 , Reply# 2   4/26/2012 at 13:23 (4,375 days old) by electron1100 (England)   |   | |
Post# 592346 , Reply# 3   4/26/2012 at 13:28 (4,375 days old) by andyzanni ()   |   | |
great thanks ! What does the 'autosense' refer to? |
Post# 592348 , Reply# 4   4/26/2012 at 13:36 (4,375 days old) by electron1100 (England)   |   | |
The machine has two thermostats on the exhaust, basically as the load drys the exhaust temperature rises, once it hits the higher temperature thermostat this switches off the heating element, so not over drying the load (in theory) Once the load has cooled down to the lower temperature thermostat setting the heater will come back on and so on, it is a simple system that works reasonably well. Gary |
Post# 592349 , Reply# 5   4/26/2012 at 13:40 (4,375 days old) by electron1100 (England)   |   | |
Post# 592350 , Reply# 6   4/26/2012 at 13:41 (4,375 days old) by andyzanni ()   |   | |
never seen a filter so bad- did it still work or cut out?? |
Post# 592351 , Reply# 7   4/26/2012 at 13:43 (4,375 days old) by electron1100 (England)   |   | |
Post# 592352 , Reply# 8   4/26/2012 at 13:49 (4,375 days old) by andyzanni ()   |   | |
aha, do you still have it? was it an exclusive? |
Post# 592376 , Reply# 9   4/26/2012 at 17:11 (4,375 days old) by jmurray01 ()   |   | |
Am I right in saying that the filters (coarse and fine) are the same as in the Bendix 7414 ? |
