Thread Number: 40031
Dishwasher Cleaner Liquids... |
Post# 592673 , Reply# 1   4/28/2012 at 13:56 (4,373 days old) by joeekaitis (Rialto, California, USA)   |   | |
They're all citric acid with colorant, perfume and maybe a non-sudsing detergent in a bottle with a wax plug that's supposed to melt if you use the Pots & Pans cycle and Sani rinse. They're useful for removing hard water scale which shows up as an ashy accumulation around the detergent dispenser and on the heating coil. You can save $4.00 to $5.00 by using a quart of white distilled vinegar (about a buck). Unload the dishwasher, put the silverware basket in its usual place, close the empty detergent dispenser, set the controls for the longest hottest cycle, purge the hot water at the kitchen sink and start 'er up. The moment you hear the detergent dispenser opening for the main wash, crack the door, wait for the spraying to stop and dump in the vinegar. Close the door and let the cycle run to completion. I've been doing it every 4 weeks since the dishwasher was installed over a year ago and it's still cleaning like a champ. |
Post# 592749 , Reply# 3   4/28/2012 at 21:05 (4,373 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Then yes, descaling products are required for anything that boils water such as kettles, dishwashers, washing machines, etc. Otherwise the limescale that forms can damage heating elements and shorten their lifespan if not the appliance as well.
Being as that may much of the problem at least where dishwashers and washing machines are concerned by using proper dosage of the proper detergent. All such products sold today contain chemicals to deal with water conditions in the area where sold. Indeed for this reason many UK/EU appliance repairmen/sites do not advise purchasing extras such as "Calgon" to prevent limescale. As for cleaning the internal parts of one's dishwasher with such products, again if the proper detergent is being used and dosed correctly there shouldn't be a build up of "gunk" inside the unit. It also does help to run the machine often at the hottest temperature which along with alkaline detergent will remove "gunk". OTHO if you are using too much detergent and or it is old/not disloving you can have crud build-up. In those cases then yes, go ahead and run some sort of DW cleaner to flush things out. |
Post# 593445 , Reply# 4   5/1/2012 at 15:23 (4,370 days old) by Rolls_rapide (.)   |   | |
Yes they do work. The liquid bottles usually contain a mixture of acids: citric and sulphamic. "Oust" dishwasher descaler powder contains lactic acid. |
Post# 593470 , Reply# 5   5/1/2012 at 16:46 (4,370 days old) by joefuss1984 (Little Rock, AR)   |   | |
I have never noticed a need in Little Rock to use them as we have fairly soft water. But my parents live in deep South East Arkansas and have fairly hard water. They have a Kenmore Ultrawash with the "Smart Wash" sensor. That is the only cycle they use. We do notice buildup occasionally and the Finish cleaner always removes it. The dishwasher is over 6 years old and still runs like a new one. It even cleans better than the Ultrawash it replaced tho it does take longer, I attribute both to the sensor. But, I digress, to me the cleaner works better than just plain vinegar and seeing how they only use it about 2-3 times a year it seems very cost effective. |
Post# 593543 , Reply# 6   5/2/2012 at 01:46 (4,370 days old) by SeamusUK (Dover Kent UK)   |   | |
Post# 593611 , Reply# 8   5/2/2012 at 08:40 (4,369 days old) by joefuss1984 (Little Rock, AR)   |   | |
I would like to say that it depends on where you live and the conditions of the water, etc. For my parents it is necessary, no amount of detergent or hot water can prevent the lime buildup that they have down there. For their needs a cleaner is necessary and vinegar wont cut it. For my water conditions it is not necessary. |
Post# 593634 , Reply# 10   5/2/2012 at 10:46 (4,369 days old) by dj-gabriele ()   |   | |
It's a shame as America dishwasher don't have water softeners, otherwise water quality wouldn't be a problem at all! |
