Thread Number: 40059
Washers that are easy to disassemble/assemble? |
Post# 593191 , Reply# 3   4/30/2012 at 17:34 (4,376 days old) by Yogitunes (New Jersey)   |   | |
Frigidaire Gallery would be one choice.....although its 27 inches across.....front to back is only 24 inches.....I think even the Asko's are similar.......you may even find and older Kenmore TL DD that came in the 24 inch wide units, granted their not super size, but will do a nice size load and fit your bill......Even a 27 inch DD Kenmore can be stripped down and taken down in pieces, and then re-assembled......
heres my FL Frigidaires.....like I said, 24 inches front to back.......take a tape measure to stores with you and check different models out...... |
Post# 593208 , Reply# 4   4/30/2012 at 19:04 (4,376 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
We are good at doing this, I recently got a full sized WP 29" dryer and Super Capacity 27" washer down a basement stairway that was less than 24" wide in an old house in DC by dissembling and reassembling them. For a rental I would go with the $800 SQ and be done with it or grab one of the last WP built DDs. If you remove the cabinet they will fit through a 24" door. The Frigidaire Front load pair that Martin suggested will not fit through a 24" door, we have tried it, LOL. Plus they are not reliable or rugged enough for rental housing. Frigidaire and GE laundry are best reserved for Yuppies [ or whatever they are called now ] that take very good care of things and send 1/2 their laundry to the cleaners LOL.
Since it is a lot of trouble to get something in there you want something that can be repaired for at least 20 years. |
Post# 593310 , Reply# 6   5/1/2012 at 06:52 (4,376 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 593321 , Reply# 7   5/1/2012 at 07:57 (4,376 days old) by Yogitunes (New Jersey)   |   | |
check again......mine is 24 inches front to back......the top has an overhang in the back, that would have to come off, and the door could come off as well to clear the handle, this should give you aprox 23 1/4 inches.....mine are 2008's, and some things may have changed, but they seem to be full featured units in a smaller cabinet.....
like I said, take a tape measure to a store with you..... |
