Thread Number: 40076
Progress on the 57 Whirlpool dishwasher |
Post# 593216   4/30/2012 at 19:45 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593217 , Reply# 1   4/30/2012 at 19:48 (4,370 days old) by turquoisedude (.)   |   | |
While the tub slipped into the cabinet frame relatively easily, getting the mounting bolts lined up again was no picnic... I had this poor thing on it's back and on it's sides trying to get the bolts lined up. I did manage to get them lined up after a good amount of cursing only to find that I should have put the rack glides.... You can imagine what I said...
Post# 593218 , Reply# 2   4/30/2012 at 19:50 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593220 , Reply# 3   4/30/2012 at 19:53 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593223 , Reply# 4   4/30/2012 at 19:55 (4,370 days old) by turquoisedude (.)   |   | |
Here's a hard-learned trick for mounting a dishwasher motor that I acquired while working on a friend's 59 Mobile Maid and my own 58 Frigidaire - do it upside down!
This post was last edited 04/30/2012 at 20:35 |
Post# 593224 , Reply# 5   4/30/2012 at 19:58 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593225 , Reply# 6   4/30/2012 at 19:59 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593226 , Reply# 7   4/30/2012 at 20:01 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593227 , Reply# 8   4/30/2012 at 20:02 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593231 , Reply# 9   4/30/2012 at 20:06 (4,370 days old) by turquoisedude (.)   |   | |
Time to get the door back on... I was dreading this because the cabinet might not have been perfectly square after being welded back together.
Nope. It was fine! What took me a while was figuring out how exactly to put the door hinges and brackets back together again. AFTER I got it together, I realized I could have simply looked at the door on the 1963 Kenmore '600' Roto-Rack still in the 'unfinished' corral in the garage... Oh well... |
Post# 593233 , Reply# 10   4/30/2012 at 20:08 (4,370 days old) by turquoisedude (.)   |   | |
Post# 593292 , Reply# 11   5/1/2012 at 04:25 (4,370 days old) by washer111 ()   |   | |
I commend your work so far! I'm sure your efforts will eventually be rewarded with lovely, clean dishes. Could I ask how that drain operates (not the water draining bit, how the water gets out thru that drain)? |
Post# 593328 , Reply# 12   5/1/2012 at 08:58 (4,369 days old) by turquoisedude (.)   |   | |
There is a solenoid-controlled lever that will pop the drain plug up, allowing the water to drain. It's not a very good shot, but in reply #7, the solenoid and part of the lever mechanism can be seen on the right hand side of the drain tube. This is the first gravity-drain dishwasher I have worked on (although the 1950 Youngstown Kitchens Jet-Tower might be....) - not familiar with these at all .... yet!!
Post# 593337 , Reply# 13   5/1/2012 at 09:27 (4,369 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Paul what a great undertaking and what a great job.
Cant wait to see the results and the surprise your working on. That door alignment why is it so hard Paul ? Washer 111 Gravity drains rock I have learned this from Robert's machine. I only saw this in commercial units only.. not for the home. Now I'm spoiled. Gravity drain at it's best. Robert's Kitchenaid. Darren k |
Post# 593401 , Reply# 14   5/1/2012 at 13:10 (4,369 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 593415 , Reply# 15   5/1/2012 at 13:56 (4,369 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
