Thread Number: 40148
tiny gray granuals in outlet water |
Post# 594360 , Reply# 1   5/5/2012 at 06:37 (4,344 days old) by Easyspindry (Winston-Salem, NC)   |   | |
. . . is that the gray grains are part of a seal breaking down. If the machine has been sitting unused for a long time, put some VERY hot water in it to allow the seals to expand. Just a thoght. Good luck. Jerry Gay |
Post# 594372 , Reply# 2   5/5/2012 at 08:41 (4,344 days old) by cfz2882 (Belle Fourche,SD)   |   | |
could be corrosion particles that came off the cast aluminum basket hub after drying out and falling off as the washer sat unused for years. |
Post# 594596 , Reply# 4   5/6/2012 at 14:44 (4,343 days old) by cfz2882 (Belle Fourche,SD)   |   | |
Hehe,that isn't off the hub like i thought it might be-too dark,big, and too many must have came from whatever was being washed and i have no idea what they could be... |
Post# 594616 , Reply# 6   5/6/2012 at 15:44 (4,343 days old) by washerfetish ()   |   | |
I actually asked my mom if she remebers anyone dumping anyting into the tub on purpose and she doesn't think so. |
Post# 594628 , Reply# 7   5/6/2012 at 16:22 (4,343 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Any chance it could be ballast to balance the tub during spin? Maybe balance ring is cracked? |
Post# 594668 , Reply# 8   5/6/2012 at 18:31 (4,343 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 594680 , Reply# 9   5/6/2012 at 19:46 (4,343 days old) by washerfetish ()   |   | |
Oh Oh , I think you are probably right! If so, what am I going to do? Can I save this thing or replace the balance ring? |
Post# 594684 , Reply# 11   5/6/2012 at 20:18 (4,343 days old) by eddy1210 (Burnaby BC Canada)   |   | |
It's the OUTER tub that is stationary and attached to the cabinet. The inner basket needs to have a ballast or weight of some kind for balance reasons. That's why when an older GE goes out of balance, the tub crashes into the side of the outer tub. You can often see the scrape marks on the sides of the outer tub when you take the basket out. I concur with the others, the ballast is cracked open. |
