Thread Number: 40381
I picked up this number of Habitat yesterday |
Post# 597730   5/20/2012 at 08:21 (4,357 days old) by chachp (North Little Rock, AR)   |   | |
I picked up this KUDS21 at habitat yesterday for $25. It was pretty filthy but I am working on cleaning it up. I don't know what the previous owners did to this machine. The inside appears as though in was run somewhere with awful water but the Water Inlet screen was clean. I guess hard water doesn't' always mean clogged screen but I thought I would check it.
The machine seems to run perfectly except for the flow thru drying unit. I can see it glowing red on the inside when it calls for heat but the fan does not seem to want to spin. I have tried kick starting it a couple of times. It will run for about 10 seconds and then stop. I have been hitting cancel when it gets to the dry cycle for fear of doing more damage. I wonder if that is why they got rid of it?
Here are some pics of the machine. I will follow this with a link to a You Tube posting of the machine running. The lower wash arm seems to move much slower than in my KDS17A. Is that normal given it is feeding the upper was arm as well? Just curious to know if the speed seems normal of if there are any other issues I should address.
Here are the issues I see with this machine. Any help/advice is always appreciated:
On a side note I couldn't get my photos to reorder the way I wanted and it seems to want to show one less than I have uploaded. As I am typing this I am wondering if that's one of the IE vs. Firefox issues. I am using Firefox. Anyone else have that issue?
CLICK HERE TO GO TO chachp's LINK |
Post# 597731 , Reply# 1   5/20/2012 at 08:25 (4,357 days old) by chachp (North Little Rock, AR)   |   | |
Here is the machine running. Does the speed of the two wash arms appear normal? I am used to my KDS17a which does close to 50 RPMs. It did fill longer than it does in the video I just had to shorten it. I fills to exactly where is it supposed to so it appears to be getting enough water. CLICK HERE TO GO TO chachp's LINK |
Post# 597732 , Reply# 2   5/20/2012 at 08:34 (4,357 days old) by chachp (North Little Rock, AR)   |   | |
Post# 597749 , Reply# 3   5/20/2012 at 11:23 (4,357 days old) by badgerdx ()   |   | |
Oh wow...that's what like my folks had to replace our original, I beieve. What year is it? |
Post# 597789 , Reply# 4   5/20/2012 at 13:09 (4,357 days old) by chachp (North Little Rock, AR)   |   | |
Post# 597793 , Reply# 5   5/20/2012 at 13:19 (4,357 days old) by appnut (TX)   |   | |
Post# 597879 , Reply# 8   5/21/2012 at 00:35 (4,357 days old) by pdub (Portland, Oregon)   |   | |
Post# 597889 , Reply# 9   5/21/2012 at 01:58 (4,356 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 597912 , Reply# 10   5/21/2012 at 05:42 (4,356 days old) by chris74 ()   |   | |
Think it will wash fine... Interesting that the middle spray arm goes anti-clockwise as opposed to the lower arm... |
Post# 597987 , Reply# 11   5/21/2012 at 13:15 (4,356 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
WP kept the Hobart pump design through the 22 series, but during the 21 series they switched to a better Emerson motor [ better built quality and fewer replacements during the 5 year parts warranty ]. The 23 machines were the last DWs that looked like a real KA but WP changed the tank base to accommodate a modified WP power-clean pump and motor assembly, this was the first really big improvement in KA DWs in a decade as it was the first KA DW ever that did not have a filter that had to be cleaned. |
Post# 597996 , Reply# 12   5/21/2012 at 14:14 (4,356 days old) by chachp (North Little Rock, AR)   |   | |
I’ll get a better pic of the machine open with the Bottom rack pulled out. I think it is the WP design because it is a wider design than my 17 series machine. I was running a Rinse cycle so I will have to try a video again of the wash cycle. This machine has only one rinse :o(. I’m not sure how I feel about that but we’ll see how it goes. I ran a full cycle last night with some really dirty dishes and they came out very well.
I doubt I will make this my daily driver because I really love my 17 series machine but this will be a great machine in the utility room for larger items that are awkward in the older machines with the single wash arm. This one does have the real Soak n’ Scrub that actually, sprays, heats, and repeats a few times. Some of the older ones seem to fill, spray, heat and drain which seems kind of pointless to me. |
