Thread Number: 40425
Bosch Classix Vario-Perfect 6 |
Post# 598245 , Reply# 1   5/22/2012 at 14:47 (4,353 days old) by aquarius1984 (Planet earth)   |   | |
Im very sure there is not an issue.
Foam and bubbles can appear on any water where there is any remnant of surfactant (IIRC) present. Couple that with the liquiding action of the pump no wonder there is a few bubbles. You seem to very worried about rinsing issues yet none of what you have said in your many posts is anything to worry about. Foam sometimes is present at the end of the wash for said reasons and sometimes the water is not always as it comes from the tap. Unless you get skin rashes and irritations (not pshycological ones from thinking about it too much) you are going to be just fine. As long as your dosing for your water hardness and soil then there is no reason why you should suffer any ill effects powder or liquid. :) |
Post# 598263 , Reply# 3   5/22/2012 at 15:54 (4,353 days old) by aquarius1984 (Planet earth)   |   | |
