Thread Number: 40467
consumer reports testing |
Post# 598845 , Reply# 2   5/25/2012 at 06:50 (4,351 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Increased cycle times to make up for the reduced water levels have lead to some front loaders being just as harsh as some top loading washers. There is so little water and froth to cushion the load laundry bangs against itself and the washer tub a bit more harshly. This leads to increase wear and tear on wash. One way around this would be to launder smaller loads to increase the water to textile ratio.
Post# 598910 , Reply# 3   5/25/2012 at 15:41 (4,351 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Seems if anyone should point it out, Consumers' should. That all this "high efficiency" nonsense is bunk. If you have to do 1/3 smaller loads to get the same results, you have to do 1/3 more of them. So where did your 1/3 savings go? The worse news is, you have to pay for the airhead bureaucrats who cooked this scheme up.
