Thread Number: 40473
Need Help |
Post# 598916 , Reply# 1   5/25/2012 at 17:08 (4,346 days old) by lebron (Minnesota)   |   | |
Post# 598921 , Reply# 2   5/25/2012 at 18:05 (4,346 days old) by DADoES (TX, U.S. of A.)   |   | |
Detergent doesn't specifically dissolve in the cup ... it mostly falls out when the cup opens and what's left it washed out by the spraying arm. If your cup not opening at all? Or it opens but there's caked detergent left when the cycle is over? That is typically caused by aged detergent, by insufficient spray pressure or volume (which in turn can have any of several causes), or by spray to the cup blocked by a large item loaded at front of the lower rack. |
Post# 598924 , Reply# 4   5/25/2012 at 18:06 (4,346 days old) by statenislandgwm ()   |   | |
LOL @ DADoES, we must have posted at the exact same time, GMTA!!! |
Post# 599060 , Reply# 6   5/26/2012 at 11:39 (4,345 days old) by norgeway (mocksville n c )   |   | |
Have you tore it up LOL! I will try to give you a call soon,..Hans |
Post# 599075 , Reply# 8   5/26/2012 at 13:59 (4,345 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
