Thread Number: 40509
WHIRLPOOL DUET AND SAGGING SPRINGS! |
Post# 599376 , Reply# 1   5/27/2012 at 23:15 (4,350 days old) by rp2813 (Sannazay)   |   | |
Post# 599384 , Reply# 2   5/28/2012 at 00:16 (4,350 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 599477 , Reply# 4   5/28/2012 at 13:28 (4,350 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes as John in Mass suggested check the shocks first, I have never seen a problem with the springs [ but this could be a first ]. My partner has had a Duet for 8 years and we always use the highest spin speed possible unless you are not using the dryer, your washer will likely last longer with the faster spin speeds [ to say nothing of your dryer or power bill ]. |
Post# 599548 , Reply# 6   5/28/2012 at 21:48 (4,349 days old) by redcarpetdrew (Fairfield, CA)   |   | |
I've replaced a few shocks on the W/P machines. The give away for me has been to look at where the upper and lower parts of the shock where they meet. If there's a fair amount of grease showing, I replace them and the issue is solved. You can get the shocks one at at time as they do not come in combo packs. It's possible you have a bad spring but, as John said, I've never had to replace one...
RCD |
Post# 599796 , Reply# 8   5/29/2012 at 23:58 (4,348 days old) by rp2813 (Sannazay)   |   | |
Post# 599870 , Reply# 10   5/30/2012 at 10:06 (4,348 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
I think your washer model might be a defective model depending on the year it was build as i have a 2004 generation 1 duet washer thats going to be by summers end 9 year old and i have no such problem, it do bnot mean that it will be problem free eternaly as its will soon be a 9 year old model. You will be lucky if you can find the actual part but some parts might not be compatible as parts go depending on the washer model and serial number.
Post# 599886 , Reply# 11   5/30/2012 at 11:49 (4,348 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 599901 , Reply# 13   5/30/2012 at 13:19 (4,348 days old) by rp2813 (Sannazay)   |   | |
We bought our Duet HT in early 2007. We had to leave it behind when we moved because it and the matching dryer were too big for the new laundry room.
Glad to hear there are three-spring models out there and that you're not imagining things -- except if yours had four springs you'd know what was wrong! |
Post# 599920 , Reply# 14   5/30/2012 at 15:25 (4,348 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 599974 , Reply# 15   5/30/2012 at 20:40 (4,347 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 599977 , Reply# 16   5/30/2012 at 20:58 (4,347 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 600150 , Reply# 17   5/31/2012 at 17:08 (4,346 days old) by stevet (West Melbourne, FL)   |   | |
John, glad to see you may have a solution.. Model is WFW9150WW00 Serial:HLY4590937 Hopefully, they made a change for the better! Thanks Steve |
Post# 602539 , Reply# 19   6/10/2012 at 23:09 (4,336 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 602607 , Reply# 21   6/11/2012 at 10:09 (4,336 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The shocks are not spring loaded. They are more of a grease filled dampening shock but I have replaced them for sagging/vibration/shake issues with success. The ends twist out but there are 1-2 tabs you push to enable them to twist. In the past, I've used a wrench to twist them until the tabs break and then remove but only if I can't get at the tabs (the tabs are on the strut base, not the tub itself. Look for a little raised 'nub' on the tub that lets you turn the strut base only one way...)
RCD |
Post# 602649 , Reply# 23   6/11/2012 at 12:49 (4,336 days old) by rp2813 (Sannazay)   |   | |
