Thread Number: 40670
Kitchenaid KDS-20 wash impeller stuck on shaft |
Post# 601584 , Reply# 1   6/6/2012 at 19:42 (4,334 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 601593 , Reply# 2   6/6/2012 at 20:20 (4,334 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Since the motor shaft is SS on this DW the Impeller usually doesn't get stuck badly, after you remove the retaining screw if you squirt in a little penetrating oil in the hole it will usually pull off with minimal prying. Since it sounds like it wants to break you will need to replace it anyway so I would go ahead and pry it off and replace the Wash Impeller. You will probably find that the drain impeller has broken veins on it and if so you need to replace it and the water seal. This was a common problem with the 18-20 KA DW pumps. |
