Thread Number: 40731
speed Queen Fl not draining |
Post# 602469   6/10/2012 at 19:51 (4,336 days old) by jocks54 (Danbury Connecticut)   |   | |
Hi guys I have a Speed Queen FL that is 4 yrs old. It has suddenly stopped draining the water out. I have checked the pump impeller and all is clear. Any suggestions that an amatuer can do? Thanks guys! |
Post# 602474 , Reply# 1   6/10/2012 at 20:07 (4,336 days old) by mrb627 (Buford, GA)   |   | |
Post# 602496 , Reply# 2   6/10/2012 at 21:16 (4,336 days old) by jocks54 (Danbury Connecticut)   |   | |
Ok Malcolm! Tell an amatuer who does have an ohm meter how to do this? Unit plugged in or not? |
Post# 602602 , Reply# 3   6/11/2012 at 09:43 (4,336 days old) by jocks54 (Danbury Connecticut)   |   | |
Thanks for being so helpful whomever you are,remaining unidentified. I thought this was a friendly group who welcomed newbies. But I suppose remaining anonymous helps to allow you to be catty! We all aren't as knowledgeable as you! |
Post# 602788 , Reply# 4   6/11/2012 at 20:13 (4,335 days old) by mrb627 (Buford, GA)   |   | |
Honestly, I haven't had the need to ohm out one of the pump motors on these machines. But I suspect there is a technical document in the console of the machine that has some troubleshooting information.
Have a look and see if the document is there. Someone that is servicing these machines in the field may be able to point you to a service manual online. Malcolm |
Post# 602864 , Reply# 6   6/12/2012 at 07:26 (4,335 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Actually you don't need to know much about electricity to figure out what is wrong. If you have removed the trap and nothing is caught in the impeller and you can turn it with your finger then try direct testing the pump. Take an old cord and attach two terminals and disconnect the machines wiring from the pump and attach the test cord and plug it into an outlet or extension cord, the pump should operate, if it seems to run put water in the machine and see if it pumps out, if not unplug everything and remove the drain hose on the pump and if the water floods out you need a new pump.
Also be sure that nothing is caught in the drain hose, and if the above experiment dose make the pump operate properly then there may be something electrically wrong in the machine. Remember these washers have a full 3 year warranty. |
