Thread Number: 40767
Easy Spindrier needs a new belt |
Post# 603117   6/12/2012 at 20:53 (4,307 days old) by marks (Tucker, GA)   |   | |
The belt is on it's last legs... I have NO idea how to replace it! There is no bolt or cotter pin on the end of the pulley and 2 bolts holding attaching the pump to the frame. I'm not sure if these 2 bolts have to come out to give it the room to drop the pulley. The motor shaft runs into the centre gear drive. It is kind of hard to see in this picture, but I'll attach it anyway. Hopefully these weren't built too differently over the years and this one is pretty much the same as all of them. The wing nut is for the belt guard, which I removed. Someone please give me some hints on how to do it!
Post# 603136 , Reply# 1   6/12/2012 at 23:34 (4,307 days old) by mickeyd (Hamburg NY)   |   | |
In your pic, do you see the rubber joiner attached to the pulley with a screw and 2 braces /clamps ? Take the clamps off, and slide the rubber joiner back. You have to push hard and you'll see a gap in the drive shaft. Slide the old belt through the gap. You have to work it through. Then slide the new belt through the same gap, re-clamp, and you're back in business. A standard Hoover classic upright vacuum belt worked for me. Your belt looks a bit different, flat rather than tubular. Would you take a pic of the front of the machine so I have a better idea of the model you have?
You can do this. The only issue is: will the Hoover belt work on your model? I'm betting it will. |
Post# 603236 , Reply# 2   6/13/2012 at 12:05 (4,306 days old) by marks (Tucker, GA)   |   | |
Good! My next question was where to locate a belt! I will look closely at it for the rubber joiner, and go for it. The vacuum belt did cross my mind, last night, so I will get one hopefully tonight. Here is a picture of the machine. I was told it was ca 1942, but if you know it, and have any more info, that would be cool!
Post# 603238 , Reply# 3   6/13/2012 at 12:16 (4,306 days old) by mickeyd (Hamburg NY)   |   | |
Take the old one with you for size matching.
Yeah, your babe is a 40's born. Your machine is very beautiful, and she's at or near 70!!!
In your pic, the rubber joiner, braced at both ends, is just below the wide hose going from the spinner to the pump.
Easy always claimed "Precision Engineering." And their drive shaft amazes me. Imagine: it has a narrow quarter-to-half inch opening, precisely engineered to remove the pump belt. I am too much a novice to know how unusual this is. Maybe one of our engineers will comment.
A BIG PS: You see where the bottom brace is almost flush against the pulley.... that is where the gap is. Once both sets of braces are unscrewed, you push back to reveal the opening. |
Post# 603252 , Reply# 4   6/13/2012 at 13:01 (4,306 days old) by marks (Tucker, GA)   |   | |
Post# 603587 , Reply# 5   6/14/2012 at 12:10 (4,305 days old) by mickeyd (Hamburg NY)   |   | |
Look at 9 o'clock exactly. That's the screw holding the brace. Unscrew the brace and work the rubble coupler. That's all you need to do to start. If you can't wiggle the belt through, then remove the brace at the other end of the rubber coupler, slide the coupler back, and the gap will appear, giving you enough room to pull the belt through. Nothing else should be dismantled. |
Post# 603791 , Reply# 6   6/15/2012 at 08:30 (4,304 days old) by marks (Tucker, GA)   |   | |
Belt done! I had to drop the motor (which is a 1/3hp GE) because the rubber buffer wouldn't push back enough to get to the opening between the motor shaft and the pump. It was ok, because I also hit the lubrication points on the motor with it down, and now it's real quiet. I had to try a few different belts until I found one that was both tight enough and narrow enough to fit. The 1st one looked good, but was just slightly too wide and rode up onto the pulley guide.
The most difficult part was the screw under the pump pully which has to come out slightly sideways to clear the edge of the pulley. I found a date of manufacture plate on the underside, and it's later than I though- 11/10/48. At least it's back in action. She's the "daily driver" for now! |
Post# 603820 , Reply# 7   6/15/2012 at 10:45 (4,304 days old) by mickeyd (Hamburg NY)   |   | |
Guess I'm the one who's lucky. I've done a belt job three or four times or so over 35 years of Easy Precision and never had to drop the motor.
So she's humming like a new born. That's great news. I was anxous that you were in too deep and I wasn't clear enough. Sweet Relief!
Hey-'48. So she's 64 like the guy in the Beatles' Song ....."Will ya still need me? Will ya still please me?.....When I'm sixty-four bummm- bum. " And the answer is, "Yes!"
What kind of belt and where from? |
Post# 603872 , Reply# 8   6/15/2012 at 12:27 (4,304 days old) by marks (Tucker, GA)   |   | |
Post# 603877 , Reply# 9   6/15/2012 at 12:39 (4,304 days old) by mickeyd (Hamburg NY)   |   | |
Yeah, It's a Model I, the economy model. There are 4 models. You have the valve on the hose to hold water in the spinner, no faucets, no spray cone in the spinner, and an attached lid which is pretty cool since it was only available on the economy model. Why they didn't engineer a nice hole in the square lid for the faucet models instead of the round detached lid is beyond me. Maybe the attached lid would have made too tight a fit with the faucet. They had to sacrifice a neat "automatic-like" feature. Too bad. It must be fun having that perma-lid.
How are you rinsing? This post was last edited 06/15/2012 at 13:11 |
Post# 603893 , Reply# 10   6/15/2012 at 13:45 (4,304 days old) by marks (Tucker, GA)   |   | |
It is really a cool machine and it washes very well! I'm on a well with limited capacity, so I usually do at least 3 loads at once. Fill it with detergent, whites, clothes, towles then drain, refill with clean water and repeat. A few times I've extra rinced using the sink sprayer in the spinner. I used to have a Whirlpool Duet (brand new as of 3 years ago, which broke 6x until I had enough) and the easy spins out drier than that did! Nice for a 64 year old machine!
Post# 603905 , Reply# 11   6/15/2012 at 15:24 (4,304 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 603907 , Reply# 12   6/15/2012 at 16:05 (4,304 days old) by luckyfind ()   |   | |
Pretty sweet machine. Having belt issues of my own. Your conversation with mickeyd gave me a few ideas. He's given me some good advice about my 60's norge restor. in the past.... Good luck |
Post# 603912 , Reply# 13   6/15/2012 at 16:22 (4,304 days old) by mickeyd (Hamburg NY)   |   | |
Post# 603917 , Reply# 14   6/15/2012 at 16:39 (4,304 days old) by marks (Tucker, GA)   |   | |
Post# 603928 , Reply# 15   6/15/2012 at 17:49 (4,304 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 603951 , Reply# 16   6/15/2012 at 21:16 (4,304 days old) by mickeyd (Hamburg NY)   |   | |
1 ~ Nothin' quicker for tackling piled up laundry than an Easy. Never had or seen the lidded one in person, like yours. Looking forward to the day.
2~ I remember when I took these pix in Winter. You were right: the filter, according to the Daily Doctrine manual, is not used the way I use it. Who knew? THE SWITCH says TWO SPEED Normal or Gentle. It's great to have, especially for a long, slow wash: kitchen stuff, white sox, stained T's, accidental skivvies (howls). |
Post# 603974 , Reply# 17   6/15/2012 at 23:42 (4,304 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
That's a VERY clean model Mickey. Does the speed switch make it a 4? But what, they ditched the chrome stripes? Boooo.
I thought the 'gearshift' controls preferable in the long run, because the cables tended to get stiff then the plastic actuators broke off from fatigue. And the brushed chrome knobs! |
Post# 603976 , Reply# 18   6/15/2012 at 23:50 (4,304 days old) by mickeyd (Hamburg NY)   |   | |
The stripes went out in the mid-50's. The 2 speed makes it a 4+, I guess.
This machine was almost NIB New in Box. There was no box, but the machine had not been used. In immaculate and pristine condition, I got it from Gregm of Worcester, Mass. It is the reigning King of the Laundry. Here's another pic I took this past Winter for Mark. High shot both faucets peeking. |
Post# 603986 , Reply# 19   6/16/2012 at 00:32 (4,304 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
A NIB Spindrier? I'm feeling faint. What a prize! King indeed. I'd be begging neighbors to do their wash.
I had the high prince, a 1973 Panasonic. No transmission, almost nothing to go wrong. DD pump and 1750 spinner, motor per function, dual speed and timed shutoff. On top of that, scrawny me could pick it up and put it in the (removed) passenger seat of a VW bug. Now that's "easy". |
Post# 604285 , Reply# 20   6/17/2012 at 18:27 (4,302 days old) by marks (Tucker, GA)   |   | |
Post# 604644 , Reply# 21   6/18/2012 at 21:28 (4,301 days old) by mickeyd (Hamburg NY)   |   | |
It's the Drain/Suds Faucet recirculating wash water through the filter in the wash tub. I'm glad you're enjoying your Easy. I wonder where it was kept or covered to keep the body in such fine condition. Remarkabe. Do you have "The Story"? Is dropping the motor easier than exposing the gap? Haven't done that.
Here's the rinse faucet with the spray cone. |
Post# 604735 , Reply# 22   6/19/2012 at 11:41 (4,300 days old) by marks (Tucker, GA)   |   | |
The rubber buffer wont squeeze back far enough to expose the gap, so the one screw in the motor side of the buffer, and the 2 screws holding the motor in are really quick.
I didn't get the story, other than it was found in a farm house in upstate NY, in the kitchen. It obviously hadn't been used in years, but luckily only took a few manual hand turns of the motor to get it running perfectly. The belt lasted about 30 loads, but was dry rotted. There is only a slight leak on the pump drain plug, which I will eventually fix (seal on the cap). I just throw a towel under it for the time being, because it isn't so bad. Do you use yours as the "daily driver"? |
Post# 604738 , Reply# 23   6/19/2012 at 11:57 (4,300 days old) by mickeyd (Hamburg NY)   |   | |
I want it to last forever, that is, as long as I'm alive and then to leave it to a fellow Easy lover. But I am favoring it right now. It is so versatile, flexible and--EASY. It's cirrently in the kitchen being used for light loads. But it's inevitable that one day I'll be aggressive and stuff it.
So it stayed in a nice warm dry kitchen. Well, that explains it. Thanks. Pic from an older Easy I keep in the basement |
Post# 604801 , Reply# 24   6/19/2012 at 15:48 (4,300 days old) by marks (Tucker, GA)   |   | |
The lower painted pannels could probably use a re-paint at some point, but they aren't horrible. There is some slight surface rust under the lip of the painted pannel, which I will sand if I decide I want to paint it. There are a few scratches in the back and on the legs, but otherwise it's in great shape!
