Thread Number: 40833
Miele Professional OctoPLUS Models |
Post# 604164   6/16/2012 at 21:15 (4,323 days old) by mrb627 (Buford, GA)   |   | |
Post# 604170 , Reply# 1   6/16/2012 at 22:25 (4,322 days old) by mysteryclock (Franklin, TN)   |   | |
Post# 604183 , Reply# 2   6/17/2012 at 00:54 (4,322 days old) by qualin (Canada)   |   | |
Could you run one of these off of a dryer outlet if you changed out the receptacle? A NEMA L6-30 looks like a twist lock connector.. I bet one of these would cost about as much as a new economy car... |
Post# 604268 , Reply# 3   6/17/2012 at 15:13 (4,322 days old) by mrb627 (Buford, GA)   |   | |
Post# 604278 , Reply# 4   6/17/2012 at 16:25 (4,322 days old) by aamassther (Hendersonville, NC )   |   | |
Post# 604289 , Reply# 5   6/17/2012 at 19:19 (4,322 days old) by mrb627 (Buford, GA)   |   | |
Post# 604345 , Reply# 6   6/17/2012 at 23:40 (4,321 days old) by qualin (Canada)   |   | |
Aaaaaack!!! I guess you would really have to be a dedicated enthusiast to be able to put aside enough money to buy one of these puppies. I wonder what the rated lifecycle of these machines are... They look beautiful..... |
Post# 604404 , Reply# 7   6/18/2012 at 08:32 (4,321 days old) by bellaboy ()   |   | |
this washer cost a bout 3000-5000 dollars in norway or 30000 nok depending on heating and draining etc it is built to last 20 years and her miele gives 10 years warranty . |
Post# 604413 , Reply# 8   6/18/2012 at 09:42 (4,321 days old) by chris74 ()   |   | |
I think this is not an appliance for a common household... |
Post# 604632 , Reply# 9   6/18/2012 at 20:12 (4,321 days old) by mrb627 (Buford, GA)   |   | |
Post# 604651 , Reply# 10   6/18/2012 at 22:34 (4,320 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 605406 , Reply# 11   6/21/2012 at 20:45 (4,318 days old) by mrb627 (Buford, GA)   |   | |
Post# 605645 , Reply# 12   6/22/2012 at 16:59 (4,317 days old) by mysteryclock (Franklin, TN)   |   | |
Expensive, but you're right - sort of in the same league as the Little Giants (only bigger.) The electrical requirements could be a big lift, though - aren't they 2 x 240v or something like that? But at least they have a drain pump model washer so you don't have to jackhammer up your concrete floor to install a drain trench!!
Post# 605678 , Reply# 13   6/22/2012 at 21:14 (4,317 days old) by mrb627 (Buford, GA)   |   | |
Post# 605685 , Reply# 14   6/22/2012 at 21:30 (4,317 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 605689 , Reply# 15   6/22/2012 at 21:53 (4,316 days old) by mrb627 (Buford, GA)   |   | |
Post# 605918 , Reply# 16   6/24/2012 at 07:17 (4,315 days old) by mrb627 (Buford, GA)   |   | |
Went down to the dealership yesterday to crunch some numbers. Seems the pricing detailed above was a little low. The Octo set would work out to around 12K in the end. Further, Miele is hesitant to sell the Octo set to residential customers because the child safety features were not built into it.
On another note, Miele Professional did point me to exactly the transformer they would use to configure the Little Giant dryer to operate on 240VAC. And it is less than $200. So now I am back to looking at the Little Giant set. Need to do some homework on how much involved an additional 240 drop to the laundry room would require. There must be a support group for people like me. Oh wait, its aw.org! Malcolm |
Post# 605919 , Reply# 17   6/24/2012 at 07:20 (4,315 days old) by bajaespuma (Connecticut)   |   | |
Post# 605921 , Reply# 18   6/24/2012 at 07:35 (4,315 days old) by mrb627 (Buford, GA)   |   | |
Post# 605937 , Reply# 19   6/24/2012 at 09:36 (4,315 days old) by bajaespuma (Connecticut)   |   | |
Post# 605970 , Reply# 20   6/24/2012 at 12:45 (4,315 days old) by mysteryclock (Franklin, TN)   |   | |
Post# 606034 , Reply# 21   6/24/2012 at 17:05 (4,315 days old) by mrb627 (Buford, GA)   |   | |
Post# 606136 , Reply# 22   6/25/2012 at 05:38 (4,314 days old) by qualin (Canada)   |   | |
Malcolm, you are seriously considering buying these? |
Post# 606163 , Reply# 23   6/25/2012 at 08:06 (4,314 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 606166 , Reply# 24   6/25/2012 at 09:04 (4,314 days old) by mrb627 (Buford, GA)   |   | |
Post# 606345 , Reply# 26   6/26/2012 at 06:15 (4,313 days old) by mrb627 (Buford, GA)   |   | |
Post# 606365 , Reply# 27   6/26/2012 at 08:20 (4,313 days old) by bajaespuma (Connecticut)   |   | |
Post# 606375 , Reply# 28   6/26/2012 at 09:26 (4,313 days old) by mrb627 (Buford, GA)   |   | |
Post# 606546 , Reply# 29   6/26/2012 at 22:13 (4,312 days old) by grahamW ()   |   | |
I have a Canadian Little Giant (PW6065) and it's wired for 240v single phase not 208v. According to my source, it is optionally available in 3phase but it isn't too common. |
Post# 762688 , Reply# 30   6/10/2014 at 07:48 (3,599 days old) by mrb627 (Buford, GA)   |   | |
Post# 765903 , Reply# 33   6/25/2014 at 15:58 (3,584 days old) by mrb627 (Buford, GA)   |   | |
Post# 765944 , Reply# 34   6/25/2014 at 17:59 (3,584 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
My guess is these washers really aren't happy on anything less than solid and firm flooring such as concrete. So to avoid complaints from unhappy customers better to nip potential sale in the bud.
My Miele W1070 will make several attempts to balance a load, but if it cannot will simply launch the spin regardless, banging and clanging away. Happily one never leaves the unit unattended and thus am around to stop the machine and usually manually rebalance the load. If you look at the difference between say my Miele and other washers from that brand and say my Oko-Lavmat the differences in suspension systems is striking. Miele machines use commercial grade shocks which along with the cast iron cradle are designed to cope with forces generated by unbalanced loads. OTOH the Lavamat's suspension seems weaker IMHO but then again the computer programming on this machine will simply abort a spin if it senses a badly unbalanced load. That or it will do so at a very reduced speed to lessen movement of the drum. |
Post# 765956 , Reply# 35   6/25/2014 at 18:43 (3,584 days old) by logixx (Germany)   |   | |
Post# 765960 , Reply# 36   6/25/2014 at 18:54 (3,584 days old) by mrb627 (Buford, GA)   |   | |
Post# 765971 , Reply# 38   6/25/2014 at 19:11 (3,584 days old) by logixx (Germany)   |   | |
Post# 804711 , Reply# 39   1/18/2015 at 08:28 (3,377 days old) by mrb627 (Buford, GA)   |   | |
Post# 804717 , Reply# 40   1/18/2015 at 08:59 (3,377 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Why not just ask Miele again and point them to that video? I guess, this move could move them a bit? |
Post# 804775 , Reply# 42   1/18/2015 at 17:07 (3,377 days old) by mielerod69 (Australia)   |   | |
Hi Malcolm,
When I worked at Miele, I was part of the Professional for the Home project. These machines had to be approved for home use by getting an energy and water label on them. Also the power had to be single phase 240 V, 25 amp to keep the running times short. A set with the pedestals here in oz sets you back $14K. |
Post# 804788 , Reply# 43   1/18/2015 at 18:29 (3,377 days old) by mrb627 (Buford, GA)   |   | |
