Thread Number: 40931
help! maytag wringer washers?? |
Post# 605652 , Reply# 1   6/22/2012 at 18:38 (4,319 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Here's my take on this whole issue...
I don't think there are really any advantages or disadvantages per-se between the J and N. The J had an 18 gallon square tub and the N had a 16 gallon round tub. So, the washing capacity of the N is slightly less that that of the J but not really enough of a difference to be significant to a collector/hobbyist. The red "trimmed" machine were made between 1940 and 1965. The turquoise "trim" machines were made from 1966 until 1982. The actual model numbering system is a bit confusing. Technically speaking (with a few minor exceptions) machines that were actually called a model "J" or "N" were only made from 1939-41. After WWII (again with a few minor exceptions which are too complicated to explain here) all models had a "2" after the letter number. Here's a breakdown of a model number for a N2LP (there are still plenty of these around) "N" is model number "2" is post WWII "L" is electric motor "P" is for water pump (the lack of a "P" means it DOESN'T have the pump) Here's another (this machine likely never existed): J2MPS "J" is model number "2" is post-WWII "M" is "Multi-Matic" gasoline motor "S" is for wringer safety pedal (introduced in the late 60s, there were LOTS of "E2LS" & "E2LPS" machines made in the 1970s and sold to old ladies who needed one last wringer machine before they died, my grandmother included!) Also, in terms of availability, Ns tend to be easier to find than Js. The J was a middle-of-the line machine whereas the N was considered lower-end (the NX was even lower, but that's a story for another post). Most people either opted for the "E2L" with its hinged lid and aluminum tub or they went with the less-featured N. In fact, Maytag ceased production of the J in the early 70s for this very reason. They made wringers until 1982 but only models E2 & N2. Also, be aware that many simply refer to machines by the first letter. Since 99% of the machines you will find out there were manufactured post-WWII the "2" is generally considered to be a given. Hope this helps some! |
Post# 605658 , Reply# 2   6/22/2012 at 18:49 (4,319 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 605659 , Reply# 3   6/22/2012 at 19:08 (4,319 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 605662 , Reply# 4   6/22/2012 at 19:23 (4,319 days old) by mickeyd (Hamburg NY)   |   | |
That's one for the archives. Yeowsuh!
Kelly, welcome!
If you're going to use the machine in an area without a nearby floor drain, make sure you get one with a pump. None of the ones pictured have a pump. You'll know a pump model when you see a raised aluminum hook rising out of the drain hose. Even if you are going to use the washer in a basement with floor drainage nearby, I recommend a "Tag," as we affectionately call them, with a pump; they're way more fun. |
Post# 605664 , Reply# 5   6/22/2012 at 19:28 (4,319 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 606758 , Reply# 7   6/27/2012 at 19:39 (4,314 days old) by stan (Napa CA)   |   | |
willing to...shall we say ...be more involved with the wash, and you will with a wringer! *LOL* you absolutely will have cleaner diapers!!
Since the wringer has no automatic controls regarding fill level, wash time, pre soak.wash temp, rinse temp, you get to control and monitor all of this this. So say for instance you are wringing out the diapers, after the first wash, and you see, or smell something, it can be dealt with right away. Like dump and refill, (with or without wringing) or agitate a little longer, ect ect After working with your machine a couple of times you'll be a pro, and find you own way of making it work for you , and the easiest for you. You and the machine will become ONE *LOL* In the past diapers were usually pre soaked over night in a mild Borax solution, or Baking soda, That you can easily do with your wringer! If you don't like, or want the Borax, then just a cool or (room temp) over night soak with mild detergent, in the morning, just empty the machine and refill with hot/warm and use what ever soap/detergent works for you, Be sure to rinse diapers well (twice)! HTH |
Post# 608273 , Reply# 8   7/4/2012 at 16:40 (4,307 days old) by Electronicontrl (Grand Rapids, MI)   |   | |
Yes Craigslist is the way to go.
I found this E2LPS 7 years ago. It was manufactured in 1970. I use it monthly for a Big washing of sheets & towels. Congrats to you for finding one with minimal use! You'll find a LOT of info on this site! There was a TIME magazine article when Maytag ceased wringer washer production in 1983. |
Post# 608325 , Reply# 9   7/4/2012 at 20:29 (4,307 days old) by stan (Napa CA)   |   | |
Post# 608330 , Reply# 10   7/4/2012 at 21:28 (4,307 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Could do a long and informative post, but someone else has nailed it already.
Pipe by scrolling down the bottom of the following: CLICK HERE TO GO TO Launderess's LINK |
