Thread Number: 40973
I used a regular front loading washer today for the first time! |
Post# 606097   6/24/2012 at 22:50 (4,295 days old) by StrongEnough78 (California)   |   | |
Well let me clarify, one that wasn't at a laundromat. It was a Kenmore maybe 5 years old, hard to tell. It did an alright job considering it seemed like there was no water in it. I watched it during the fill and it seemed to dispense a good amount of water, but there was no splashing at all or suds for that matter. It looked to have 3 cycles. Regular, Eco-Wash and Delicate. It had 3 different spin settings, slow, normal and fast. Extra rinse options and I think 6 different water temperature settings. All functions were by knobs, no buttons. I used the Regular heavy wash cycle, extra rinse and fast spin on all 3 loads I did. The first load I used warm wash warm rinse. Hot water flow was more than sufficient since the window glass was very warm to the touch, even at the end of the cycle. The last load was a hot wash and again the hot water flow was great cause the glass was pretty hot during the wash. I switched it over to Warm/Warm for the rinse cycles since the hot wash only had a cold rinse. Over all I guess I was happy with the results. I would have liked to seen more water in there for some more splashing and a little suds. The wash action seemed a bit slow to me though. And the fast spin speed didn't come until the final spin. I'm not sure what the R.P.M.'s are during the spin but it was pretty fast. My clothes came out a bit drier than from a top loader, but not as much as I was expecting. I used Sears Ultra Plus detergent. I used about half of that little scoop per load. I think that's what it calls for in a front loader. I probably wouldn't object to using it again but I think I would prefer a top loader over it. Luckily there was no mildew or musty smell in it. The owners DO use hot water washes luckily. Not bad but not totally impressed. I prefer my clothes submerged in water. Clothes seem to come out a bit fresher that way.
Post# 606098 , Reply# 1   6/24/2012 at 23:00 (4,295 days old) by StrongEnough78 (California)   |   | |
Unfortunately I didn't get a picture of the set I used, but I found a picture of a very similar set to give you an idea. Here's the link.
CLICK HERE TO GO TO StrongEnough78's LINK on eBay |
Post# 606099 , Reply# 2   6/24/2012 at 23:06 (4,295 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 606100 , Reply# 3   6/24/2012 at 23:08 (4,295 days old) by StrongEnough78 (California)   |   | |
Post# 606107 , Reply# 4   6/25/2012 at 00:04 (4,295 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
From your description it sounded like my Frigiwhite and from the picture it is EXACTLY. The same product was sold as Frigidaire, GE, Kenmore and in Europe as Electrolux, who designed it. White owns the Frigidaire badge, imported and assembled it for the ones they don't own.
Spin is 800, not remarkable but adequate. You saw a later model, the originals had no spin speed selection. Other than, the 800 spin was only the last minute of 'regular'. W&W and delicate, as well as all intermediate spins, were 550. The rinse temp switch only affects final rinse, intermediates are always cold. Mine is 12yo and has not needed repair. That's something right there. Straightforward design, nothing fancy, less to go wrong. Can't explain why you saw no water except it does not "climb up" the door. If no suds, you didn't put enough detergent for soil or water conditions. The directions on the box are VERY generic. |
Post# 606110 , Reply# 5   6/25/2012 at 00:15 (4,295 days old) by StrongEnough78 (California)   |   | |
Well I've used the same amount in the Speed Queen front loaders at the laundromat. I think they are double maybe even triple load. There's a higher water level in those and the suds to accumulate. I use the Sears Ultra Plus which rarely ever suds to begin with, but I do notice quite a bit when I use it in a front loader. But not the one today lol. Clothes did come out clean from what I could tell, so I know I used enough.
Post# 606116 , Reply# 6   6/25/2012 at 00:57 (4,295 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
I get some stuff really dirty and even after 12 years with the same washer and Tide HE I still have to adjust detergent amount once the machine is running. I don't know the characteristics of Sears detergent.
If the water climbs up the glass it's much easier to see/evaluate suds. Water doesn't climb the glass in ElectroWhiteGEpoolaires. |
Post# 606117 , Reply# 7   6/25/2012 at 01:02 (4,295 days old) by StrongEnough78 (California)   |   | |
Post# 606121 , Reply# 8   6/25/2012 at 01:54 (4,295 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
If the tumble were any faster the clothes would centrifugally cling to the drum and not 'plop' in the water like they're supposed to.
The model you saw and the one I own may be different, though the picture you linked to is identical. The model did evolve as it went along. Mine is early, 1998. Yes they use little water. The water level is set about 2" below the glass. How much splashing you see depends on the load. Imagine how much worse the current "high efficiency" machines are. Especially with regard to rinsing. Can't rinse in a gawldang tablespoon of water. I'm a rinseaholic and this machine rinses thoroughly. |
Post# 606122 , Reply# 9   6/25/2012 at 01:57 (4,295 days old) by StrongEnough78 (California)   |   | |
Post# 606753 , Reply# 12   6/27/2012 at 19:29 (4,292 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
