Thread Number: 40990
A long weekend well-spent OR Two out of three ain't bad... |
Post# 606303   6/25/2012 at 22:19 (4,314 days old) by turquoisedude (.)   |   | |
It was a long weekend here in Quebec (the St-Jean-Baptiste Holiday weekend) so, guess who was busy messing around with vintage laundry equipment??
First up: the 63 GE V-12 washer. I finally got the leak on the filter-flo recirculation hose patched (a new one is on the way, but well, I an anxious to get this one into the Ogden Laundry!). However I ran into an issue with the water valve. Thanks to experience and the Repair-Master for GE Washers, I figured the problem might be due to a foreign object blocking the valve or a damaged diaphram. Luckily, it was the former not the latter. After a good cleaning, the valve was working reliably once again. |
Post# 606304 , Reply# 1   6/25/2012 at 22:20 (4,314 days old) by turquoisedude (.)   |   | |
Post# 606305 , Reply# 2   6/25/2012 at 22:22 (4,314 days old) by turquoisedude (.)   |   | |
And a spin test! I bypassed the lid switch for future viewing pleasure - it shakes around a bit, but all will be well once installed in the Ogden Laundry!
CLICK HERE TO GO TO turquoisedude's LINK |
Post# 606306 , Reply# 3   6/25/2012 at 22:24 (4,314 days old) by turquoisedude (.)   |   | |
Post# 606307 , Reply# 4   6/25/2012 at 22:28 (4,314 days old) by turquoisedude (.)   |   | |
Post# 606308 , Reply# 5   6/25/2012 at 22:29 (4,314 days old) by turquoisedude (.)   |   | |
Post# 606309 , Reply# 6   6/25/2012 at 22:30 (4,314 days old) by turquoisedude (.)   |   | |
Post# 606310 , Reply# 7   6/25/2012 at 22:31 (4,314 days old) by turquoisedude (.)   |   | |
Post# 606311 , Reply# 8   6/25/2012 at 22:33 (4,314 days old) by turquoisedude (.)   |   | |
For the heck of it, I tried a suds-return test. Forgive my gushing, but this is the first working suds return that works!
Post# 606312 , Reply# 9   6/25/2012 at 22:36 (4,314 days old) by turquoisedude (.)   |   | |
And last but not least... The V-12 GE dryer... This is the not so good news from the weekend. Although I found a set of original drum rollers, they are not quite the right ones. I need to figure out how to mount the wider rollers - I think longer carriage bolts will do the trick and I hope that I can find them this week. To be continued....
Post# 606342 , Reply# 10   6/26/2012 at 05:23 (4,313 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 606348 , Reply# 12   6/26/2012 at 06:46 (4,313 days old) by pulltostart (Mobile, AL)   |   | |
Post# 606360 , Reply# 13   6/26/2012 at 07:38 (4,313 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Paul, Did you turn the timer dial ahead to get that low water level in the 51 Kenmore during the agitation demo? It normally fills higher. |
Post# 606364 , Reply# 14   6/26/2012 at 08:11 (4,313 days old) by bajaespuma (Connecticut)   |   | |
Post# 607037 , Reply# 15   6/29/2012 at 09:29 (4,310 days old) by turquoisedude (.)   |   | |
Tom - funny but there are flakes of porcelain missing from both the washer and dryer in the V12 set - I suspect it was due to rough handling, though. About the water level in the 51 Kenmore - you are absolutely right - I 'cheated' and advanced the dial to the 'wash' section. I haven't lifted the lid on this one yet (that's the plan for Sunday - I have to work tonight and tomorrow due to my 'promotion' at work) so I don't know what kind of water level cutoff there may in this one. I suspect it will be a 'tube and plunger' as seen in the Whirlpool washer manual that popped up this week in the Daily Doctrine Dispenser (and I HAD to have...LOL).
Darren - can't wait to get the filter-flo pan!!
Lawrence - I hope to get that dryer put back together this weekend - however I will have to make some very tough choices as to where to put them.... EEP!
Ken - I am not sure that I would be able to pull off a 'formal' wash-in (unless I send hubby to Brazil... LOL) but if your journeys this summer bring you into New Hampshire or Vermont, Ogden is pretty darn close... |
Post# 607783 , Reply# 16   7/2/2012 at 22:14 (4,307 days old) by turquoisedude (.)   |   | |
While most folks had a long Canada Day weekend, I was, alas working Friday and Saturday (until Midnight - ugh!). I guess the new position at work has its responsibilies...
BUT by Sunday mid-morning, I was back down in Ogden and itching to keep going on the trio of appliances in the garage. I wanted to get the new rollers into the GE DA920 dryer, but found that the rolllers I bought are not quite the exact ones for the 1963 model... I needed to get some longer bolts which seem fine, but there's a bit too much 'play' on the rollers which I fear will come back to bite me... I have a couple of ideas but I think I won't be trying to rely on this dryer as 'the daily driver'.... |
Post# 607784 , Reply# 17   7/2/2012 at 22:17 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607785 , Reply# 18   7/2/2012 at 22:20 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607786 , Reply# 19   7/2/2012 at 22:22 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607788 , Reply# 20   7/2/2012 at 22:25 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607791 , Reply# 21   7/2/2012 at 22:28 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607793 , Reply# 22   7/2/2012 at 22:29 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607795 , Reply# 23   7/2/2012 at 22:32 (4,307 days old) by turquoisedude (.)   |   | |
And for once, I learned my lesson... I figured that pulling the water valve for the Kemore would be a good idea. Let's face it, after timers, washer water solenoids are the most problematic component for me! I took the valve out, tested it, and found the cold water input was stuck. Well, with a careful cleaning, I got it working again!
Post# 607797 , Reply# 24   7/2/2012 at 22:35 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607798 , Reply# 25   7/2/2012 at 22:36 (4,307 days old) by turquoisedude (.)   |   | |
Post# 607800 , Reply# 26   7/2/2012 at 22:39 (4,307 days old) by turquoisedude (.)   |   | |
I scrubbed down the rest of the cabinet - it is in amazing shape!
That's it for this weekend... This coming weekend, I'll be having a garage sale to clear some clutter but I'll not be able to play with machines, but the Kenmore is moving toward the basement and I am working on find ing the matching dryer! Stay tuned... |
Post# 607809 , Reply# 27   7/2/2012 at 23:07 (4,307 days old) by PhilR (Quebec Canada)   |   | |
Post# 607810 , Reply# 28   7/2/2012 at 23:07 (4,307 days old) by mickeyd (Hamburg NY)   |   | |
Post# 609300 , Reply# 29   7/9/2012 at 21:16 (4,300 days old) by turquoisedude (.)   |   | |
Michael - I used some CLR on the tub rim and a general purpose cleaner and degreaser on the outside - I swear that I am going to wax this cabinet before the washer gets moved into the basement!
THAT may be a while off, though... This weeked was a busy one, spent holding a garage sale down in Ogden so I didn't get to fiddle with the machines all that much. I started with the GE dryer and my attempts to fit the drum rollers that I recently bought (I found two, new in the box on eBay) but when I got them I had a devil of a time trying to get them installed. Well, I spat and cursed and after commiserating with Phil, he suggested that I try to fit a bushing in the roller shaft. I found some at a local industrial supply place on Friday night, but they were too big for the roller shaft. I was too tired to argue with them, so I put them aside. I saw in the 59 GE service manual (only downloaded it tonight) that the rollers I bought are, in fact, the drive wheels for the 1959 DA920... AARGH!! So, opinions please - should I give up on the rollers I have and try and find the correct part OR should I keep going on adapting the 1959 rollers. My fear is that I going to totally ruin a part that someone else may really need some day... And now the washer saga... I had a positively nutty day Saturday, the first day of the sale and after a tiring and frustrating one, I figured that a full cycle test on the newly-reassembled 1951 Kenmore washer. I was very pleased with myself for having unclogged the water inlet valve so I figured 'Well what else could possibly go wrong'... Fool... The tub seemed to never really get full, but there was no sign of a leak anywhere from under the washer. Turns out the water was gushing out of the suds drain/return hose. My first thought was the suds return valve - I drained the washer and ran to the Whirlpool/Kenmore Repair-Master. I jumped to the conclusion that the suds return valve had some kind of obstruction that was keeping the suds port open. After getting back to town (and another discussion with Phil) I had a new possible cause - the fact that I had the drain hose on the garage floor (running to a sump pump drain hose) was causing a syphon and draining the tub... Again, I defer to the owners of suds return machines - does this sound like a possible cause or is the suds valve the problem?? As always, all comments and suggestions (not hubby's) are welcome! |
Post# 609306 , Reply# 30   7/9/2012 at 23:01 (4,300 days old) by mickeyd (Hamburg NY)   |   | |
The hose must be in a sink or standpipe, or as you now well know, it will drain by gravity. In later machines, when the drain ports were moved to the top of the cabinet, then you can place the hose on the floor. Happy to help.
Degreaser? A second product after the cleaner?
And how many machines did Hubby covertly try to disguise as covered tables and then sell at the garage sale? |
