Thread Number: 41079
Todays Crescent Dishwashers |
Post# 607415   7/1/2012 at 08:46 (4,310 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Doctrine is so Kewl!
LOVE THAT!! This post was last edited 07/01/2012 at 09:03 |
Post# 607422 , Reply# 1   7/1/2012 at 09:39 (4,310 days old) by labboy (SD, CA)   |   | |
Post# 607565 , Reply# 3   7/2/2012 at 05:57 (4,309 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 607609 , Reply# 4   7/2/2012 at 09:45 (4,309 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 607677 , Reply# 5   7/2/2012 at 15:08 (4,309 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 607724 , Reply# 6   7/2/2012 at 17:47 (4,309 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 607872 , Reply# 8   7/3/2012 at 06:37 (4,308 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 608246 , Reply# 9   7/4/2012 at 13:42 (4,307 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
where is that UM now sitting??
jon I see the ghost view now, Eddie, thank you. The ball bearings are outside the spray tub and the wash arm must depend through the top supported by the bearing and the water must be injected into the arm below the top of the machine. So the ball bearing never sees the wash liquor. Thanks |
Post# 608270 , Reply# 10   7/4/2012 at 16:05 (4,307 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 608284 , Reply# 11   7/4/2012 at 17:41 (4,307 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 608339 , Reply# 12   7/4/2012 at 22:18 (4,306 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 608342 , Reply# 13   7/4/2012 at 22:25 (4,306 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I have no idea about Permanent Magnet Motors. But as I type, my imagination is making sense right now. Common sense is telling me about it.
As I recall, when those CM machines fired up, All you heard was the motor start and then just the water being sprayed though the Wash Arms. Vaguely any Motor noise at all. Hey... Wheres Melvin been (supremewhirlpool) ??? He's the Triple Phase Grand Kahuna. I love reading his post about conversions. |
Post# 609196 , Reply# 15   7/9/2012 at 07:16 (4,302 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
