Thread Number: 41138
Hoover Logic 1300 A3636 |
Post# 608138 , Reply# 1   7/4/2012 at 05:20 (4,311 days old) by Hoover1100 (U.K.)   |   | |
full frontal; |
Post# 608139 , Reply# 2   7/4/2012 at 05:22 (4,311 days old) by Hoover1100 (U.K.)   |   | |
Love how the flash lights it up! Yes it needs a replacement door seal :) |
Post# 608140 , Reply# 3   7/4/2012 at 05:24 (4,311 days old) by Hoover1100 (U.K.)   |   | |
Very flexible for a machine of it's time! This model was manufactured June 1988. |
Post# 608141 , Reply# 4   7/4/2012 at 05:27 (4,311 days old) by Hoover1100 (U.K.)   |   | |
Lots of them! |
Post# 608143 , Reply# 6   7/4/2012 at 05:43 (4,311 days old) by electron1100 (England)   |   | |
I had one of these and I loved it too, mine was white and i had a matching dryer.
To re-set the time cursor, you will need to take the programmer off (three screws two on the top and one underneath) once you have moved this back away you will see three toothed pulleys with the cursor band around them. The band is toothed and what you need to do is in effect move it over the toothed pulleys to the correct position, BUT you must not move the centre pulley from its position as this lines up with the shaft on the timer, so gently pull the band down awayfrom the middle timer pulley and move it in which ever direct it needs to go to line up. If any of that make sense then good, if not ask me again Gary |
Post# 608154 , Reply# 8   7/4/2012 at 06:09 (4,311 days old) by electron1100 (England)   |   | |
Post# 608158 , Reply# 9   7/4/2012 at 06:30 (4,310 days old) by electron1100 (England)   |   | |
Post# 608170 , Reply# 11   7/4/2012 at 06:45 (4,310 days old) by electron1100 (England)   |   | |
Hello Mat
When you get a suitable screwdriver try and get a magnet and magnatize it makes putting in screws in akward places a lot easier Yes thats the float bowl they are sods to get off and also undoing the white plastic crocodile clamps is a sod without breaking them. if you do break them i just use jubilee clips if it does look crudded up then it is best to take it off and clean it out with bits of wire running water etc. |
Post# 608172 , Reply# 12   7/4/2012 at 07:12 (4,310 days old) by Hoover1100 (U.K.)   |   | |
I guessing then it's just a case of yanking the float bowl hard enough that it comes off? It feels like its connected to the tub by something inside the black rubber tube. |
Post# 608183 , Reply# 13   7/4/2012 at 08:22 (4,310 days old) by electron1100 (England)   |   | |
Yes once you have disconnected the clamps you have gently twist it back and forth and pull back, you are right there is a plastic tube inside the rubber one.
I have on occasions snapped this getting it off, in wich i removed it all and just connected the float bowl with the rubber tube only without any problems |
Post# 608243 , Reply# 14   7/4/2012 at 13:27 (4,310 days old) by hotpoint95622 (Powys)   |   | |
Post# 608286 , Reply# 15   7/4/2012 at 17:44 (4,310 days old) by Hoover1100 (U.K.)   |   | |
Had to stop this afternoon as a friend came over, but I'm off work again tomorrow too so I shall finish the job then! Will update on how it goes! :) |
Post# 608296 , Reply# 16   7/4/2012 at 18:17 (4,310 days old) by aegokocarat (United Kingdom)   |   | |
They have got the exact same model of this washer in st fagons museum :-) |
Post# 608375 , Reply# 17   7/5/2012 at 04:32 (4,310 days old) by fido ()   |   | |
I've never heard the pressure vessel called a float bowl! |
Post# 608384 , Reply# 18   7/5/2012 at 07:34 (4,309 days old) by electron1100 (England)   |   | |
Post# 608388 , Reply# 19   7/5/2012 at 07:43 (4,309 days old) by Hoover1100 (U.K.)   |   | |
Managed to get it off in the end, broke the plastic tube in the middle but all sorted now, there was a bit of crud in the tube but not a great deal, this is the low water level after cleaning it, how does this look? |
Post# 609189 , Reply# 21   7/9/2012 at 06:26 (4,305 days old) by electron1100 (England)   |   | |
