Thread Number: 41176
Servis TT 2 in 1 pipe. |
Post# 608834   7/7/2012 at 09:18 (4,310 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 608835 , Reply# 1   7/7/2012 at 09:19 (4,310 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 608836 , Reply# 2   7/7/2012 at 09:21 (4,310 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 608837 , Reply# 3   7/7/2012 at 09:22 (4,310 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 608838 , Reply# 4   7/7/2012 at 09:23 (4,310 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 608849 , Reply# 5   7/7/2012 at 09:47 (4,310 days old) by lancethecook (Driffield England)   |   | |
When are you coming to do mine? There's an old hoovermatic with your name on it here as well. |
Post# 608853 , Reply# 6   7/7/2012 at 10:00 (4,310 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 608854 , Reply# 7   7/7/2012 at 10:12 (4,310 days old) by ozzie908 (Lincoln UK)   |   | |
Yes both valves only water out its the only way I could think of doing it !
I will have to find the Serial number but yes its cream, I have a MK1 now as well I am working on which is mostly white with a retro green panel just like the one you have, But its going to be sprayed white along with the casing as I wanted an all white one as that was what my Mums was. Lance if you want it done to yours I can do so very easily and Hmm thank you ever so for the Hoovermatic :) Not told himself yet I have some more coming lol will have to do some thinning out ! Austin |
Post# 608912 , Reply# 9   7/7/2012 at 18:39 (4,309 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 608953 , Reply# 10   7/7/2012 at 23:55 (4,309 days old) by ozzie908 (Lincoln UK)   |   | |
Its made to hold the filler hose as it has the same shape fixing as the spin rinse, I assume its just for making it possible to close the lid of the wash tub while you fill it. Never used it myself apart from to store the 2nd hose before conversion.
Maybe our Mike can shed more light on it than I ? Austin |
Post# 608976 , Reply# 11   7/8/2012 at 05:15 (4,309 days old) by fido ()   |   | |
It would be better if you could find some plain rubber hose rather than the ribbed stuff, which is really meant to have rubber cuffs at the ends. |
Post# 608980 , Reply# 12   7/8/2012 at 06:25 (4,309 days old) by electron1100 (England)   |   | |
Post# 609059 , Reply# 13   7/8/2012 at 14:12 (4,309 days old) by slowspin66 (lincoln uk)   |   | |
Post# 609060 , Reply# 14   7/8/2012 at 14:22 (4,309 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1070165 , Reply# 15   4/30/2020 at 20:06 (1,455 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Are the one-way valves and the Y fitting? Cause I知 thinking about doing this to my machine but I知 having trouble finding a Y fitting |
Post# 1070223 , Reply# 16   5/1/2020 at 02:57 (1,455 days old) by keymatic (London / UK)   |   | |
Dear All,
Does anyone know any good rubber restorer ? I have a Servis twinline hose in store but every year that goes by it is getting weaker and weaker, I have been using "Son of a gun" silicone spray restorer but just wondered if international friends have good experience with any other products ?? Cheers Keith |
Post# 1070233 , Reply# 17   5/1/2020 at 04:25 (1,455 days old) by ozzie908 (Lincoln UK)   |   | |
I will measure them for you but it may take a while as they are in the back of the half renovated shed. I do remember purchasing the one way valves from a boat chandler and they have graduations on them to fit all sizes, as for the Y piece it was from eBay I will see what I can find out for you.
Austin Keith I too used son of a gun applied liberally and put the pipe in a plastic bag to allow absorption of said product its stopping further disintegration but its not on the machine yet ! |
Post# 1070234 , Reply# 18   5/1/2020 at 04:33 (1,455 days old) by ozzie908 (Lincoln UK)   |   | |
I have found them on eBay and I hope the link works, if not the size I used was 17mm
Austin CLICK HERE TO GO TO ozzie908's LINK on eBay |
Post# 1070263 , Reply# 20   5/1/2020 at 09:45 (1,455 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1070496 , Reply# 22   5/2/2020 at 16:55 (1,453 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1070501 , Reply# 23   5/2/2020 at 17:07 (1,453 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
I知 just waiting for the parts to arrive |
Post# 1070528 , Reply# 25   5/2/2020 at 19:38 (1,453 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
This one is what my twin tub sounds like CLICK HERE TO GO TO Adam-aussie-vac's LINK |
Post# 1070589 , Reply# 26   5/3/2020 at 07:21 (1,453 days old) by ozzie908 (Lincoln UK)   |   | |
I would say they need a good oiling including the pump as its sounding like its been dry for some time. If you can get at the bearings easily enough drop some oil in them see if it helps...
I would turn the whole thing upside down and run oil down the spinner shaft and yes ok the bearings may want replacing but its not as bad as some I have encountered. Keep us posted. Austin |
Post# 1070606 , Reply# 28   5/3/2020 at 08:57 (1,453 days old) by ozzie908 (Lincoln UK)   |   | |
Hi Adam I have posted all my replies to you same as I have this one !!
I believe there is a breather hole but it should not be too hard to locate and stop it up. Have not encountered any major leaking of oil when I have turned mine over I don't leave it too long just enough to oil the moving parts I cannot get at normally ! Austin |
Post# 1070624 , Reply# 29   5/3/2020 at 11:12 (1,453 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
I just thought in the last one you accidentally called me Austin, my bad, how long would it take someone to flip it over and is there a Technique to it? |
Post# 1070628 , Reply# 30   5/3/2020 at 11:37 (1,453 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1070668 , Reply# 31   5/3/2020 at 18:04 (1,452 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
I値l do it a bit later today I値l take some pictures and I値l let you know |
Post# 1070744 , Reply# 32   5/4/2020 at 04:30 (1,452 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Easily able to get to the pump bearing although I had a bit of an issue getting to the main spin bearing as it is underneath a dome/cup shaped pulley So what should I do in regard to that? |
Post# 1070747 , Reply# 33   5/4/2020 at 05:29 (1,452 days old) by ozzie908 (Lincoln UK)   |   | |
You could if you felt brave enough remove the spin pulley to allow you to get to the bearing, Or spray it with aerosol oil which may help but won't be as long lasting. If you are going to remove the dome pulley put the machine on its side so as to prevent oil spillage from the gearbox when you have it removed you can up end it to oil it.
Austin |
Post# 1070770 , Reply# 34   5/4/2020 at 09:15 (1,452 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
But which side should I have Facing up,knobs up or back up? |
Post# 1070807 , Reply# 35   5/4/2020 at 13:13 (1,452 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1070870 , Reply# 36   5/4/2020 at 19:56 (1,451 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Do you know how to remove the pulley? |
Post# 1071071 , Reply# 37   5/6/2020 at 06:57 (1,450 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
So I don稚 mess anything up |
Post# 1071073 , Reply# 38   5/6/2020 at 07:27 (1,450 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1071202 , Reply# 40   5/7/2020 at 10:52 (1,449 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1071286 , Reply# 41   5/8/2020 at 05:02 (1,448 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Although I do think the bearing might have to be replaced but I am honestly not sure how to do that |
Post# 1071287 , Reply# 42   5/8/2020 at 05:10 (1,448 days old) by ozzie908 (Lincoln UK)   |   | |
You might want to leave that as long as you can because trust me its not an easy fix, It can be done but you need the right bearings and a new seal and a lot of hard work, you have to remove the wash deck as the spin can only comes out the top. I and a few other have done it and its a long hard slog. Getting the new parts will be a beast of a job too.
