Thread Number: 41184
Whirlpool Duet Help! :/ |
Post# 608958 , Reply# 1   7/8/2012 at 00:13 (4,303 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 608991 , Reply# 2   7/8/2012 at 07:21 (4,302 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 609038 , Reply# 4   7/8/2012 at 12:00 (4,302 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Is it just during tumble or when the pump is running? Is the crackling-scraping noise fast or slow? Run your hands (carefully) over all the holes in the drum to see if you may have a foreign object caught in one of the holes that is rubbing on the outer tub as the basket turns. I worked on one of these the other day that had a bad pump that sounded like what you describe, but you'd obviously only hear that when the pump is running.
Post# 609327 , Reply# 5   7/10/2012 at 00:30 (4,301 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 609342 , Reply# 6   7/10/2012 at 05:36 (4,300 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Maybe the drain check ball has come apart and the shell of it is rolling around in between the tubs?
CLICK HERE TO GO TO tecnopolis's LINK |
Post# 611424 , Reply# 9   7/21/2012 at 05:48 (4,289 days old) by freshlinen (south africa)   |   | |
what washing machine is in your photo? |
Post# 611596 , Reply# 10   7/22/2012 at 16:50 (4,288 days old) by ozzie908 (Lincoln UK)   |   | |
