Thread Number: 41581
1992 Kenmore Gas dryer, no flame |
Post# 613557   7/30/2012 at 19:34 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
This machine has run well for two years, I replaced the HotSurfaceIgnitor on day one, 2 years ago. Then yesterday, no heat. It's a Kenmore 1992 full sized gas dryer, WP Build, timer has "Auto Sense" Hi heat, AutoSense Lo, Timed, and air fluff, MOL or so model. No real moisture sensing, simply the "timer versus heat" cycling. The HSI is intact, everyone I've ever replaced were visibly horrid, crumbling and 15 years old, this one gives me 0 resistance on my Ohm meter. |
Post# 613559 , Reply# 1   7/30/2012 at 19:42 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
but here's what has me wondering what's up-------the connector, 2 wires, going from a harness at the gas valve directly to the igniter only gives me about 25.3V. Shouldn't I be getting 120?
It appropriately only gets voltage when a heat cycle is chosen, not on air fluff, that aspect is good. Where to look next? What to check next? It's a wonderful dryer, I can't imagine it is too rough a repair or too pricey.
I'll check voltage or resistance anywhere anyone tells me to, thanks in advance. I haven't yet checked any thermostats. Since the HSI doesn't heat up red hot, I am starting here. |
Post# 613563 , Reply# 2   7/30/2012 at 19:59 (4,286 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Not sure when WP added the thermal "fuse" to the exhaust manifold but pull the back off and see if there is a small white plastic thing mounted near the thermostat and wired in series with it. I'll post of picture of one below. The thermal fuse melts if the output temp in the exhaust gets dangerously high. They sometimes fail for no good reason and sometimes they fail doing exactly what they are supposed to do!
Also, check the continuity of the thermostat itself. A failed thermostat after 20 years is certainly not unheard of. |
Post# 613574 , Reply# 4   7/30/2012 at 21:14 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
The thermal fuse has 0 resistance, that's good. When I tested voltage at the igniter, it's 27V with the thermal fuse hooked up, it's 10V with both leads off the thermal fuse?????? Still the HSI does not even get warm, entirely room temp. Isn't this all supposed to be 120? Or is the gas valve section of the wiring a 24V system?
Model #110-97273100
Thank you two for advice, but still stumped here for now |
Post# 613577 , Reply# 5   7/30/2012 at 21:51 (4,286 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 613581 , Reply# 6   7/30/2012 at 22:06 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 613587 , Reply# 7   7/30/2012 at 22:23 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Dave------2 checks on that thermal cutout--------0 resistance, perfect conductivity. Then, with both leads off of it, I wired them to each other for a final check, plugged it back in, and still 27Volts at the HSI. So I am still stumped. It is entirely 120volts everywhere, that I have confirmed with testing the HSI on 120. Non-resettable thermal fuse seems fine, thermal cutout thermostat on the duct bulkhead seems fine, still only 27 volts at the HSI . HMMMM..... It's almost bedtime, next I'll try my hand at deciphering the electrical schematic, not my forte, but seems next in line.
Thanks guys, I'll keep you posted-- Mark
Post# 613592 , Reply# 8   7/30/2012 at 22:36 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 613607 , Reply# 9   7/30/2012 at 23:58 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 613660 , Reply# 11   7/31/2012 at 07:24 (4,286 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 613665 , Reply# 12   7/31/2012 at 07:38 (4,286 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 613919 , Reply# 14   8/1/2012 at 07:27 (4,285 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Congratulations on finding the problem Mark, this repair exercise shows one of the pit falls of using a volt meter to diagnose electrical problems, sometimes you can do better by doing a few basic tests and keeping your eyes open to any possible clues as to the failure.
When you tested the voltage getting to the entire gas burner assembly you only were getting about 25 volts naturally leads one to believe the problem is in the dryers electrical system somewhere. But the meter does not place enough load on the dryers heat circuit to always get an accurate reading, this is when the old fashioned approach of using a 60 watt test light actually worked much better better as you would have taken a better look at the burner assembly when the light lit.
My suggestion that you have a dirty centrifugal switch or timer contact is probably true but it will never likely cause a problem because the ignitor draws more that 300 watts and will burn through any dirt, oil ? on the contacts each time the dryer is used.
I was in a home about a year ago looking at a customers old WP DW that would not fill reliability. When you advanced the timer through all the different fill periods of a full cycle you were lucky to get it to fill for even a few seconds. The kitchen had had a bad problem with roaches in the recent past and I figured that the timer contacts may just be dirty and since a fill valve coil only draws 10 watts of power the voltage would not get through a dirty timer contact. I noticed a portable electric heater sitting in the corner of the kitchen, so I took the two wires off the inlet valve coil and plugged them on the male prongs of the heaters plug, turned on the heater and slowly turned the DWs timer through a cycle. I then reconnected the wires to the inlet valve and the DW filled perfectly and is still working today as I was back the other week to repair the customers ice maker and she commented that the 25 year old DW was still working great. |
Post# 614417 , Reply# 15   8/3/2012 at 10:48 (4,282 days old) by akronman (Akron/Cleveland Ohio)   |   | |
