Thread Number: 41672
help?!! |
Post# 614633 , Reply# 1   8/4/2012 at 12:54 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614635 , Reply# 2   8/4/2012 at 12:57 (4,281 days old) by boschlover1997 ()   |   | |
ive checked the brushes and they are fairly long, ill taker a pic and see what you think. |
Post# 614643 , Reply# 3   8/4/2012 at 13:26 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614654 , Reply# 4   8/4/2012 at 14:45 (4,281 days old) by boschlover1997 ()   |   | |
which spring? and whats the armature? |
Post# 614660 , Reply# 7   8/4/2012 at 15:21 (4,281 days old) by boschlover1997 ()   |   | |
the thing the brushes go on make sense as when i wiggle the wires to the brushes.. it works.. kinda. so glad the module is so cheap. brush one |
Post# 614661 , Reply# 8   8/4/2012 at 15:23 (4,281 days old) by boschlover1997 ()   |   | |
brush 2 |
Post# 614662 , Reply# 9   8/4/2012 at 15:24 (4,281 days old) by boschlover1997 ()   |   | |
the yellow cable |
Post# 614663 , Reply# 10   8/4/2012 at 15:25 (4,281 days old) by boschlover1997 ()   |   | |
the brown cable |
Post# 614664 , Reply# 11   8/4/2012 at 15:27 (4,281 days old) by boschlover1997 ()   |   | |
back of motor |
Post# 614665 , Reply# 12   8/4/2012 at 15:28 (4,281 days old) by boschlover1997 ()   |   | |
front of motor |
Post# 614666 , Reply# 13   8/4/2012 at 15:32 (4,281 days old) by boschlover1997 ()   |   | |
whats the black stuff?? |
Post# 614667 , Reply# 14   8/4/2012 at 15:34 (4,281 days old) by marthalover4eve ()   |   | |
just were carbon has worn off thats the black stuff |
Post# 614668 , Reply# 15   8/4/2012 at 15:36 (4,281 days old) by boschlover1997 ()   |   | |
so by looking at the pics what do you thinks wrong? |
Post# 614669 , Reply# 16   8/4/2012 at 15:44 (4,281 days old) by brummybear (Birmingham uk)   |   | |
The commutator is the copper bit that the brush presses against it should be quite shiny it has slots in it the electricity transfers from the brush to the commutator causing it to spin.
It should be shiny and clean with no scratches, it can be cleaned with WD40 sprayed on a cloth and wiping it ( I don't recommend spraying the motor as some of the newer ones use nylon in the bearing as nylon and WD don't like each other) Pull Gently on the brush and make shure its moving freely and springy.. Supermaticjames is right the control board my be on it's way out and are easy to find and cheep. Re-fit the motor and run the machine with a lode in, when the motor goes into spin see if there's any arcing from where the brushes sitt againt the commutator. Id there is a LOTT of arcing then the motor needs replacing ( again EBAY quite cheeply) Let us know how it goes. |
Post# 614670 , Reply# 17   8/4/2012 at 15:49 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614672 , Reply# 18   8/4/2012 at 15:50 (4,281 days old) by boschlover1997 ()   |   | |
yeah sure, give me a sec it will be up shortly. |
Post# 614675 , Reply# 19   8/4/2012 at 15:54 (4,281 days old) by boschlover1997 ()   |   | |
heres the pic |
Post# 614676 , Reply# 20   8/4/2012 at 15:58 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614680 , Reply# 21   8/4/2012 at 16:04 (4,281 days old) by boschlover1997 ()   |   | |
yeah motor spins fine, although it does slow down quite quickly |
Post# 614683 , Reply# 22   8/4/2012 at 16:09 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614686 , Reply# 23   8/4/2012 at 16:12 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614687 , Reply# 24   8/4/2012 at 16:16 (4,281 days old) by boschlover1997 ()   |   | |
so your sure its the armature?? |
Post# 614689 , Reply# 25   8/4/2012 at 16:19 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614691 , Reply# 26   8/4/2012 at 16:27 (4,281 days old) by boschlover1997 ()   |   | |
okay whats the best website of getting them from? |
Post# 614692 , Reply# 27   8/4/2012 at 16:31 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614696 , Reply# 28   8/4/2012 at 16:43 (4,281 days old) by boschlover1997 ()   |   | |
okay so i need to take the armature out and give it a clean? and then test it again? |
Post# 614698 , Reply# 29   8/4/2012 at 16:50 (4,281 days old) by brummybear (Birmingham uk)   |   | |
Post# 614701 , Reply# 30   8/4/2012 at 17:06 (4,281 days old) by boschlover1997 ()   |   | |
will do that tomorrow |
Post# 614810 , Reply# 32   8/5/2012 at 05:24 (4,280 days old) by boschlover1997 ()   |   | |
thats exactly as the fault is. without the belt on its fine, with the belt on and no load, it gets to 1000 slowly and with a load applied it barely gets past slow bosch speed.:) |
Post# 614826 , Reply# 33   8/5/2012 at 06:33 (4,280 days old) by boschlover1997 ()   |   | |
so how do i sort that one out then? |
Post# 614834 , Reply# 34   8/5/2012 at 06:53 (4,280 days old) by hotpoint9534 (UK)   |   | |
Replacement armatures are still available for these GEC/GDA motors in the link below. As a previous poster said, the commutator should be nice and shiny. Tom CLICK HERE TO GO TO hotpoint9534's LINK |
Post# 614836 , Reply# 35   8/5/2012 at 06:59 (4,280 days old) by boschlover1997 ()   |   | |
cheers |
