Thread Number: 41700
Maytag A206 Transmission Help |
Post# 615195 , Reply# 1   8/6/2012 at 19:12 (4,279 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It looks like that trany took on some water judging by the rusty parts. The bolts may have rusted and broke when you tried to loosen them or you turned them the wrong direction. They can be drilled out and replaced and the holes re-tapped, the bigger problem is what is the condition of the agitator shaft and the top bearings in the cover and don't forget to replace the O ring in the bottom of the lower case even if it has not been leaking before the re-build. |
Post# 615200 , Reply# 2   8/6/2012 at 19:28 (4,279 days old) by qsd-dan (West)   |   | |
Never had that happen to me, but I'm pretty sure I have a spare if you need it. The bolts for the cover are on the short side. Are you sure they broke?
Make sure you have these parts on hand to do the job correctly: 22204012 Stem seal and boot kit Y0A4298 Agitator Drive shaft seal 204013 Tub bearing kit 210632 Transmission gasket 210286 Lower O-ring 200744 Tub Bolt & gasket assy (short) (you'll need 2) 205254 Bolt & gasket assy (long) (you only need 1) 210183 Groove Pin for upper shaft. (Only needed if removing upper shaft in upper trans housing) 210315 Fiber Pinion 211483 Splined washer 211484 Lug washer |
Post# 615214 , Reply# 3   8/6/2012 at 20:33 (4,279 days old) by akronman (Akron/Cleveland Ohio)   |   | |
This has worked for me in similar situations
Available at Home Depot and Lowe's, hardware/drill department CLICK HERE TO GO TO akronman's LINK |
