Thread Number: 41787
Rust Stains on Whites |
Post# 616127   8/10/2012 at 16:35 (4,270 days old) by kb0nes (Burnsville, MN)   |   | |
I was talking to a buddy of mine last night and he has reported recently starting to see rust stains on freshly laundered dress shirts. He didn't catch them until they were hung up after drying. The washer is a Whirlpool direct drive (WTW5700SW0) and the dryer is an older Whirlpool (LE5780XKW0).
The dryer was professionally serviced about a year ago to replace massively destroyed rear drum rollers. Washer has never been touched. Both have been in a townhouse and seen fairly light duty. I'd suspect the dryer, but I haven't seen the spots. He suspects the washer but to me that seems more remote. Any likely causes come to mind? Phil |
Post# 616138 , Reply# 1   8/10/2012 at 16:57 (4,270 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 616140 , Reply# 2   8/10/2012 at 16:59 (4,270 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I would think more of the washer as a culprit rather than the dryer. If you can't see any rust spots in the dryer drum, then it's probably not the dryer. There is a product called Iron Out that will remove the rust stains from the shirts. Available at most hardware stores. |
Post# 616158 , Reply# 4   8/10/2012 at 18:17 (4,270 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I would most likely guess the rear drum seal on the dryer. You can take a folded scrap of white cloth folded over a blunt knife and drag it through the rear drum seam between the seal and the baulk head and see if you get a similar colored stain, as Allen mentioned you will have to use a rust removing product to remove this stain from clothing. If this is the cause the dryer drum should be removed and the seal replaced and the edge of the bulkhead repainted with a good spray paint.
Things that contribute to this type of problem are use of fabric softener sheets, too much fabric softener in washer coupled with too little detergent and cold water washing, poor rinsing of clothing and possibly a clogged or restricted vent system on the dryer. |
