Thread Number: 41792
Is there such think as Dishwasher Abuse? |
Post# 616166 , Reply# 1   8/10/2012 at 19:07 (4,275 days old) by washer111 ()   |   | |
A cup! That dish was pre-rinsed, to save our plumbing from "clogged" arteries... |
Post# 616167 , Reply# 2   8/10/2012 at 19:12 (4,275 days old) by washer111 ()   |   | |
After the Regular cycle. I wasn't particularly tempted to use Delicate today... Although I trusted myself enough to not use the Heavy or Heavy Eco cycle! |
Post# 616173 , Reply# 3   8/10/2012 at 19:26 (4,275 days old) by washer111 ()   |   | |
Came out great. I'm starting to think this DD is also beginning to remove years of burnt on garbage, as there is less and less after each run in the DD (if ever so slight!) |
Post# 616353 , Reply# 7   8/11/2012 at 15:16 (4,275 days old) by DADoES (TX, U.S. of A.)   |   | |
I *rarely* clean the filters on my unit. I'd say maybe 5 times in 8 years. I scrape to about the same degree as shown in your pics. Probably wouldn't have pretreated the casserole quite as much as you did. However, my older unit has different cycle sequences. All cycles except Fast allow two wash periods. I use 1 to 1-1/2 tsp detergent in the prewash dispenser cup, except in very light-soil situations. Interestingly also, my drain filters are an older style that don't have the fine-mesh screen. |
Post# 616356 , Reply# 8   8/11/2012 at 15:37 (4,275 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
I rarely even look at my filters..... until I started using this fiber stuff. YUCK! |
