Thread Number: 41797
Kd10 expert needed |
Post# 616235   8/10/2012 at 23:26 (4,268 days old) by marty (Central Point, Oregon)   |   | |
I am trying to take the flange and pump mount of of the dishwasher as there is a leak.. Do you need a special tool for the flange? Also are there any tricks to taking the main motor plate off? I want to replace all gaskets at once. Thanks! Martin |
Post# 616309 , Reply# 1   8/11/2012 at 12:23 (4,268 days old) by marty (Central Point, Oregon)   |   | |
Anyone? |
Post# 616321 , Reply# 3   8/11/2012 at 13:10 (4,268 days old) by marty (Central Point, Oregon)   |   | |
Thanks for the reply! I have removed the horizontal motor, but the mounting plates are stuck and I want to install new gaskets. This not a gravity drain model, if that helps. Marty |
Post# 616433 , Reply# 5   8/11/2012 at 21:46 (4,267 days old) by stevet (West Melbourne, FL)   |   | |
Marty, I sent you an email with some stuff that may be of some help. Steve |
Post# 616464 , Reply# 6   8/11/2012 at 23:55 (4,267 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
The Dreaded Cast Iron Parts.
Good Luck with those, when I needed a Drain Valve for my KD2-P stevet found one of the last 2 NIB @ Hobart. That was Not a cheap part but I'm glad I got it. That KD2-P will probably outlast my KDS-18 and KDS-20. However, Good luck finding what you need. Stevet will figure it out. (Right Steve ???) |
Post# 616520 , Reply# 7   8/12/2012 at 10:19 (4,267 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 616543 , Reply# 8   8/12/2012 at 11:18 (4,267 days old) by marty (Central Point, Oregon)   |   | |
Thanks John! I just emailed you. Marty |
