Thread Number: 41818
My Mieles |
Post# 616489 , Reply# 1   8/12/2012 at 02:54 (4,246 days old) by ian_p61 (Melbourne Australia)   |   | |
Hi again! I put it on a cycle and it did not spin what is wrong!! Thanks P.s none of the bottoms were pressed down!! |
Post# 616595 , Reply# 2   8/12/2012 at 16:22 (4,245 days old) by ian_p61 (Melbourne Australia)   |   | |
Does it need brushes!! What type?? And what about the door? |
Post# 616656 , Reply# 3   8/12/2012 at 19:56 (4,245 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
My mother had an older version of the W423, without those buttons. Hers only had a round door release button. Hers always did a graduated spin, four short spinds with tumbling in between before it went into final spin.
I don't know what the economy button did. IIRC one of the things was four rinses instead of five. Not sure though. If you use the door button and you hear a click but it doesn't really open, it could be that the door is lowered. If it doesn't click, the electric door release might be broken or does not get power. If it doesn't spin, it might indeed be the brushes of the spin motor. It still can wash because there are separate wash and spin motors. |
Post# 616689 , Reply# 4   8/12/2012 at 22:32 (4,245 days old) by ian_p61 (Melbourne Australia)   |   | |
I also noticed that the drain pump seemed to leak a tiny bit when washing, i had just cleaned it out. There was only a seal on the washing machine but not the plug thanks all |
