Thread Number: 41822
Identify Kitchen Aid DW ? |
Post# 616524   8/12/2012 at 10:26 (4,267 days old) by Riick ()   |   | |
Can anyone identify this KA, and if so, is it worth owning? Thanks !! ---- Rick |
Post# 616545 , Reply# 1   8/12/2012 at 12:08 (4,267 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 616569 , Reply# 3   8/12/2012 at 14:30 (4,267 days old) by cyclemonitor ()   |   | |
beginning of the plastic control panel |
Post# 616571 , Reply# 4   8/12/2012 at 14:34 (4,267 days old) by cyclemonitor ()   |   | |
Page 2 |
Post# 616573 , Reply# 5   8/12/2012 at 14:36 (4,267 days old) by cyclemonitor ()   |   | |
page 3 |
Post# 616574 , Reply# 6   8/12/2012 at 14:38 (4,267 days old) by cyclemonitor ()   |   | |
page 4 |
Post# 616576 , Reply# 7   8/12/2012 at 14:40 (4,267 days old) by cyclemonitor ()   |   | |
page 5 |
Post# 616577 , Reply# 8   8/12/2012 at 14:43 (4,267 days old) by cyclemonitor ()   |   | |
page 6 |
Post# 616580 , Reply# 9   8/12/2012 at 14:46 (4,267 days old) by cyclemonitor ()   |   | |
page 7 |
Post# 616582 , Reply# 10   8/12/2012 at 14:53 (4,267 days old) by cyclemonitor ()   |   | |
Page 8 |
Post# 616583 , Reply# 11   8/12/2012 at 14:55 (4,267 days old) by cyclemonitor ()   |   | |
page 9 |
Post# 616584 , Reply# 12   8/12/2012 at 14:56 (4,267 days old) by cyclemonitor ()   |   | |
page 10 |
Post# 616586 , Reply# 13   8/12/2012 at 15:00 (4,267 days old) by cyclemonitor ()   |   | |
page 11 |
Post# 616587 , Reply# 14   8/12/2012 at 15:04 (4,267 days old) by cyclemonitor ()   |   | |
page 12 |
Post# 616592 , Reply# 15   8/12/2012 at 15:44 (4,267 days old) by rp2813 (Sannazay)   |   | |
Post# 616605 , Reply# 16   8/12/2012 at 17:02 (4,267 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 616674 , Reply# 17   8/12/2012 at 21:26 (4,267 days old) by cyclemonitor ()   |   | |
page 13 |
Post# 616675 , Reply# 18   8/12/2012 at 21:28 (4,267 days old) by cyclemonitor ()   |   | |
page 14 |
Post# 616676 , Reply# 19   8/12/2012 at 21:29 (4,267 days old) by cyclemonitor ()   |   | |
page 15 |
Post# 616677 , Reply# 20   8/12/2012 at 21:33 (4,267 days old) by cyclemonitor ()   |   | |
back page |
Post# 616750 , Reply# 21   8/13/2012 at 07:35 (4,267 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Most 23s did not have plastic control panels, in fact they had very heavy dia-cast metal panels. One of the nice things about the architectural models with the 6" high control panels was that your custom wood panels from your old worn out KD 16-17 DW would fit these new taller tub machines.
WP greatly improved he racks and upper rack wheels durability in the 23 series over the earlier Hobart design and construction. On the upper adjustable racks the flat vinyl coated side rails were changed to SS because this area often had problems with the vinal coating splitting along the top and bottom of the rail and then would rust badly. WP also beefed up and enlarged the tank mounted wheels for the top rack as the original Hobart design had a lot of problems with not only broken wheels but you also had to be very careful when the rack was fully loaded to pull and push it only from the center. This is common sense to most of us but many customers just grab the corner of a top DW rack and shove it in or pull it out and the original KA rack often had problems with broken wheels when this was done. |
Post# 616757 , Reply# 22   8/13/2012 at 08:16 (4,267 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I had a KUDI-23, bought in '95. A friend of mine worked in Contractor Sales at NE Furn. Mart and I think I paid less for the KA than a comparable Maytag at the time - bulk buying power! It was a great dishwasher, WP did make some improvements as John mentioned - they also turned the detergent dispenser 180 degrees so the bi-metal actuators were above any possible water leaks coming from the dispenser cover stems.
Post# 616761 , Reply# 23   8/13/2012 at 09:02 (4,266 days old) by labboy (SD, CA)   |   | |
