Thread Number: 41860
Bendix 7159 pressure switch |
Post# 617232 , Reply# 1   8/15/2012 at 12:25 (4,242 days old) by electron1100 (England)   |   | |
Hello Matt
If you blow into the pressure switch you should hear the switches change contacts as the pressure rises and falls, if it doesnt do this then it is a safe bet its gone. I am not familiar with pressure switch used in these machines, but you should be able to substitute a more modern one, though you will have re-set it for the water levels Gary |
