Thread Number: 41982
Building a GE FF from scratch |
Post# 618513 , Reply# 2   8/19/2012 at 22:15 (4,238 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
or there is always the option of buying an old set like this old 1970 eaton viking set washer and dryerstrip it a part use the cabinet of the washer replace the control board with a ge control board replace the top that has the side lid with a genuine ge top modify it for those that would like a mini basket option paint it in the color of there choice and voila a ge ff washer
Post# 618520 , Reply# 4   8/19/2012 at 23:26 (4,238 days old) by badgerdx ()   |   | |
OMG! Eaton Vikings, Pierre... I hadn't thought of Eaton's in AGES and just yesterday I was telling someone about them. HOW FUNNY~! |
Post# 618567 , Reply# 5   8/20/2012 at 06:47 (4,238 days old) by pulltostart (Mobile, AL)   |   | |
Post# 618569 , Reply# 6   8/20/2012 at 06:58 (4,238 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This could be done in theory, but why. Even if you could do this you would likely end up with a lower quality machine than if you found a very low mileage washer and just put everything that needed attention back into like new condition.
The Reason, quality control on replacement parts is sometimes not as good as when the machines were in full production. And many NIB parts you will find and use are as old as the original machine would have been anyway and have deteriorated just sitting there in a box. This is why a new car or appliance will often go 100,000 miles on the original hoses, belts, spark plug wires etc but once you start replacing parts the replacements often do not last as long as the original parts did.
An Appliance Repair friend of mine tried to rebuild a 1978 LKM about ten years ago by replacing every mechanical and electrical with brand new parts. The machine came out great but he was surprised when in the first year or so the machine suffered several failures of what were brand new parts.
It is just much easier for the factory to assemble a high quality machine when they have complete control of the whole process. |
Post# 618575 , Reply# 7   8/20/2012 at 07:21 (4,238 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 618596 , Reply# 8   8/20/2012 at 10:11 (4,238 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Speaking of other threads, in one recently I mentioned having "re-parted" a 1983 Kenmore washer that had been parted out by a sales and repair buddy of mine. This was in 1992 or so. The machine was less than 10 years old, and I had to buy a baseplate for it. The original had been consumed in the repair of another machine more easily saleable by my friend. The rebirthing of that machine was quite fun and educational.
At that point I wondered about the same thing - is it possible to build a WP/KM belt-drive washer completely from parts. Just as John said, the answer was "well, technically speaking YES, it can be done", however, even back in 1992 there were challenges to building a copy of even the most recently built belt-drive, which were made only 6-years earlier. It you want to be true to your plan and use nothing but factory repair/replacement parts, even at six or seven years, some pieces were hard to find. A new cabinet being the toughest, followed by the console. There were four or five commonly used consoles for BDs in 1986 but by the early 90s their parts supply stock was gone. Common service parts would be easy, but the not often replaced items would have been difficult. Today it would be nearly impossible, even with much better search technology to find slow-moving parts stached here and there. The baseplate I bought was $82 if I recall. It had bearings pressed in, but no upper and lower seals. I can't imagine the repair bill to actually use one of those for a customer. We estimated that a parts-built BD would have cost over $1000, even at wholesale parts prices. This was 20 years ago... Gordon |
Post# 618764 , Reply# 9   8/20/2012 at 20:29 (4,237 days old) by geextrarinse (Hudson Valley, New York )   |   | |
Post# 618836 , Reply# 10   8/20/2012 at 23:12 (4,237 days old) by doug (West Virgina)   |   | |
Post# 618951 , Reply# 11   8/21/2012 at 11:36 (4,237 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
I have an extra Stainless steel basket from a newer GE I thought of having modified to fit the Filter-Flo. The newer tub uses a mounting hub and it is that hub that would need to be drilled to accept the filter flo tub mount.
I spoke to a welder about possibly welding something together and he was afraid the Newer tub hub was made of "pot" metal and would not stand up to any temperatures welding would create. :( He also mentioned it would be very hard to get everything "hubcentric" to eliminate any balancing issues. Not to big a deal for washing, but not ideal when spinning. |
Post# 618953 , Reply# 12   8/21/2012 at 11:42 (4,237 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
It would be easy to modify a drain pump from any washer or dish washer to act as a re circulation pump, the rub would be in creating an opening deep enough into the outer tub to provide for pickup and prevent cavitation. It would also be very noisy since it would have to run constantly during the wash cycle, sometimes as long as 14 minutes?
And I would also have to create some kind of balance ring as I don't think the upper stainless steel tub would be able to resist deformation during a high spin without some kind of bracing. |
Post# 618958 , Reply# 13   8/21/2012 at 11:46 (4,237 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 619042 , Reply# 14   8/21/2012 at 19:43 (4,236 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 619043 , Reply# 15   8/21/2012 at 19:45 (4,236 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 619044 , Reply# 16   8/21/2012 at 19:57 (4,236 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 619057 , Reply# 17   8/21/2012 at 20:40 (4,236 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 619139 , Reply# 18   8/22/2012 at 08:24 (4,236 days old) by fido ()   |   | |
I was expecting this thread to be about a fridge freezer! |
