Thread Number: 41983
A little tip for Neptune owners.. |
Post# 618532 , Reply# 1   8/20/2012 at 00:26 (4,260 days old) by AutoWasherFreak ()   |   | |
Kirby to the rescue LOL. |
Post# 618580 , Reply# 2   8/20/2012 at 08:01 (4,260 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 618584 , Reply# 3   8/20/2012 at 08:14 (4,260 days old) by Yogitunes (New Jersey)   |   | |
You had an issue, and fixed it, with what options you had available....YOU GO!....
a vacuum on BLOW or SUCTION, can work wonders on many things.....I personally use a wet/dry vac, or better yet, compressed air.... even use of an old WaterPic can clean out the smallest of areas... for a few Neptunes, or any front loader I have gotten, if it called for a teardown, like bearing replacement, then it got the full monty cleanout....otherwise, a few HOT washes with dishwasher detergent, and spraying other areas with Tilex Deep Root Mildew remover took care of everything else.... you will take our ideas, and add some of your own, and find the methods that work best for you......keep it up! |
Post# 618693 , Reply# 5   8/20/2012 at 15:40 (4,260 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 618739 , Reply# 6   8/20/2012 at 18:51 (4,260 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Unless someone is conferrable tearing the machine completely apart there other ways to get them acceptability clean, but if you want it factory clean you may have to take it apart. In your case I would try cleaning by using Martins suggestions and see how it goes.
I have two machines in my home laundry that I have never gotten completely clean on there own, one is my 1954 Frigidaire WO-65-2 which still has a sour smell when it gets wet from slime under the top of the machine [ stinky washers is not an entirely new problem ] and my 1965 LKM gas combo, on this one I know that it still has some lint build up in the outer tub. |
