Thread Number: 42020
Superba Monterey 21 repair |
Post# 618827 , Reply# 1   8/20/2012 at 22:53 (4,258 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
This machine is based off of the Hobart WM-series undercounter warewashers. No commercial DW pump is designed to ingest garbage. .
I do belive somewhere between the Whirlpool(who built this DW) and Hobart(It's based on their design) guys could steer you in the right direction. I know the commercial Hobart's better than the home ones so I won't venture a guess. Welcome to AW.org. WK78 |
Post# 618838 , Reply# 2   8/20/2012 at 23:18 (4,258 days old) by rp2813 (Sannazay)   |   | |
Post# 618853 , Reply# 4   8/20/2012 at 23:40 (4,258 days old) by rp2813 (Sannazay)   |   | |
Oh, the fine mesh filter. Yeah, that's not stainless and the whole thing would need to be replaced.
The crud on the stainless filter could be a combination of detergent and hard water residue. Running a cycle once in a while with a cup or two of white vinegar added after the tub fills should keep that under control going forward. |
Post# 618862 , Reply# 5   8/21/2012 at 00:09 (4,258 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Apologies; if I sound like an ignorant simpleton, its becasue that's basically what I am.M Don't worry about it. Remember not everyone knows everything. We learn by asking questions and there are people here who know the answers. If ya' don't ask how are you gonna learn? Welcome! |
Post# 618932 , Reply# 7   8/21/2012 at 08:37 (4,257 days old) by stevet (West Melbourne, FL)   |   | |
See how the bushing will move up and close off the opening? Is your wash arm support doing the same thing? |
Post# 619131 , Reply# 10   8/22/2012 at 08:07 (4,256 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
not sure what you mean by ..."one is the failure of the washarm support itself where the plastic wears out and the water sprays right out of the bottom of the lower arm and back into the sump.."
do you mean that flat white part at the very top of the spindle, the groove wears flat and allows water to flush out under the black center of the wash arm?? |
Post# 619150 , Reply# 12   8/22/2012 at 09:25 (4,256 days old) by dustin92 (Jackson, MI)   |   | |
Sorry to hijack this thread, but is the bad wash arm support common on the later whirlpool powerclean/ kenmore ultra wash models? Our wash arm seems a bit loose. |
Post# 619163 , Reply# 13   8/22/2012 at 10:50 (4,256 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 619183 , Reply# 14   8/22/2012 at 11:44 (4,256 days old) by dustin92 (Jackson, MI)   |   | |
Ok thanks! |
Post# 619261 , Reply# 19   8/22/2012 at 17:18 (4,256 days old) by stevet (West Melbourne, FL)   |   | |
Put together with the washarm. The new wash arms no longer have the cleanout plugs though they are still available from Hobart. I had some of them welded closed with a small stainless cover. |
Post# 619551 , Reply# 20   8/23/2012 at 16:43 (4,255 days old) by recyclewasher ()   |   | |
Hi Stevet, I'll take you up on your offer for the part numbers thanks |
