Thread Number: 42060
Quieting down an older dishwasher... |
Post# 619386 , Reply# 1   8/23/2012 at 01:48 (4,263 days old) by qsd-dan (West)   |   | |
Post# 619394 , Reply# 2   8/23/2012 at 02:46 (4,263 days old) by rp2813 (Sannazay)   |   | |
Dan, Jim has both a Maytag and a Superba, but I'm guessing this inquiry involves the KitchenAid.
On later KitchenAid models they used thick rubberized sheets around the tank and inside the door to reduce noise. Your machine should at least be wrapped with fiberglass insulation around the tank. If there's none in the door or behind the lower access panel, you can install your own with some spray adhesive. The higher the density the better. I'd even go the extra step and install some behind the kick plate too.
Hobart didn't hype the 16 and 17 series machines as "a hurricane in a box" for nothing!
Ralph |
Post# 619401 , Reply# 3   8/23/2012 at 05:24 (4,263 days old) by appnut (TX)   |   | |
Post# 619451 , Reply# 4   8/23/2012 at 09:15 (4,263 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 619642 , Reply# 7   8/23/2012 at 22:53 (4,262 days old) by qsd-dan (West)   |   | |
