Thread Number: 42231
Washing Pillow Case & Sheets advice |
Post# 621530 , Reply# 1   8/31/2012 at 07:42 (4,254 days old) by aeg03 (London, UK)   |   | |
Pic 2 - The stains were not on the items until they were washed. |
Post# 621532 , Reply# 2   8/31/2012 at 07:44 (4,254 days old) by aeg03 (London, UK)   |   | |
Pic 3 Stains like this are scattered across the cover |
Post# 621565 , Reply# 3   8/31/2012 at 10:37 (4,254 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 621571 , Reply# 4   8/31/2012 at 11:06 (4,254 days old) by mrboilwash (Munich,Germany)   |   | |
Hard to tell from the pictures, but you can check for greasy deposits by ironing the spot. If the stains melt into the fabric (getting bigger) then you know it cannot be mold or lint.
My guess is you need to use a lot more detergent. I would rewash the sheets using the "heavy soil" dosing! By any chance, do you use ointments or Vaseline or moisturizers for your skin? A maitenance wash at 95° before rewashing might be a good idea, or if the sheets can take it boil them with LOTS of detergent. If it is mold (what I don`t believe) use a powder with oxygen bleach. |
Post# 621742 , Reply# 6   9/1/2012 at 10:15 (4,253 days old) by Haxisfan (Europe - UK / Italy)   |   | |
I was wondering... when did it start happening? If you can recall when you first experienced this scenario and probably associate that particular period of time with something else that you might have been starting to do or some new product you started to use.
On the lines of what 'mrboilwash' was saying, although you little sis doesn't use those afore-mentioned products, any residue can still be easily transferred from your garments to hers during the wash. Have you done any maintenance wash recently? A couple of months ago, I used a cap (about 35ml) of milton in the washer and i set it on its longest programme on cold. It smelled of bleach afterwards, only until the first wash... but now it smells fresh all the time (until next time). I feel this will be my maintenance wash from now on ;-) |
Post# 621770 , Reply# 7   9/1/2012 at 12:53 (4,253 days old) by zanussi_lover (Nottingham, UK)   |   | |
Are you sure it hasn't got anything to do with the drum lifter filter, in the drum, as this machine doesn't have a regular fluff filter on the exterior of the washer, but you can only access the filter in the drum, via the blue trap door on one of the lifters.
Perhaps this has something to do with it? |
Post# 621844 , Reply# 9   9/1/2012 at 17:53 (4,253 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 621952 , Reply# 10   9/2/2012 at 03:27 (4,253 days old) by Haxisfan (Europe - UK / Italy)   |   | |
M8y in all honesty I wouldn't personally put up with that. If you're saying that it's been doing that since day 1, it means to me only 1 thing: the appliance is not fit for the purpose: it should clean laundry at best... rather than causing alien blemishes on it!
This is maybe due to a congenital anomaly with your particular machine (this sounds human... well!). If I were you... I should hurry back to the shop I purchased it from and demand a replacement/repair... you have evidence to prove the results of this dubious performance. Good luck... and let us know how it goes. PS: I feel strongly in saying that this CANNOT be caused by low water level... if (only 'IF') the latter was to be blamed for poor wash performance, it certainly wouldn't trigger the appearance of odd stains here and there. |
Post# 621954 , Reply# 11   9/2/2012 at 04:10 (4,253 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 622012 , Reply# 16   9/2/2012 at 08:44 (4,252 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 622017 , Reply# 19   9/2/2012 at 09:52 (4,252 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Doesnt at all Alex, I bet when used on the correct programme the results will be different, have been using my sisters ZWD14279W1 washer dryer and there is deffo a difference with higher water levels, slower agitation and rinses on synthetics..
Hi Emmanuel, have been using a faghore washer dryer FWD612 6kg 1200rpm, usually wash 2 large duvet covers (Poly Cotton) when used on cottons I get excess creasing and when on synthetics less......recently have been using a classic Servis Quartz 4.5 kg drum, was in a rush so stuffed both in expected creasing but thought as its raining the dryer will drop the creases....well with the higher water levels they where washed better and with hardly any creases....just goes to show - play with the variables and you get different results...so raise that water level (correct programme for fabric with extra rinse) and see what happens, do let us know how you get on!!! |
Post# 622044 , Reply# 20   9/2/2012 at 11:50 (4,252 days old) by aeg03 (London, UK)   |   | |
I agree Superelectronic. As I know other machines out there can cope, it's up to me to find It. I'll wait until the 12 month warranty is over then I'll consider my options. Thanks. |
Post# 622151 , Reply# 22   9/2/2012 at 20:07 (4,252 days old) by optima (Cumbria England)   |   | |
