Thread Number: 42276
How Hard Is My Water (US Only) |
Post# 622101   9/2/2012 at 18:11 (4,251 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Here is a map put out by the US Geological Survey about the water hardness in different parts of the U.S. CLICK HERE TO GO TO whirlcool's LINK |
Post# 622103 , Reply# 1   9/2/2012 at 18:16 (4,251 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
And here is a map what kind of levels you have in the U.S. You can select PH factor, Turbidity, etc. CLICK HERE TO GO TO whirlcool's LINK |
Post# 622149 , Reply# 2   9/2/2012 at 20:02 (4,251 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 622167 , Reply# 3   9/2/2012 at 20:46 (4,251 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
The map showed this area to have very soft water? I dont think so. My well water is so hard it corodes anything metal and leaves stains on all the fixtures. I have to use a water softner with the iron remover salt and then tap water tastes like its from the ocean. There is so much granite in the earth here that leaches everything from iron down to radon into the soil. Some neighbors have good well water, but I must be on a bad vein. I have been toying with the idea of just pumping it from the lake in front of my house, which is very soft.
Post# 622252 , Reply# 4   9/3/2012 at 08:39 (4,250 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 622519 , Reply# 6   9/4/2012 at 08:48 (4,249 days old) by mark_wpduet (Lexington KY)   |   | |
Hmmm
That map makes Lexington-Fayette water look moderately hard I suppose, which it is. I do not know anyone personally that has a water softener here; though I'm sure there are people who have them. I don't have one. I do know if I use a humidifier it clogs and faucets collect minerals after a while and there is never a single SUD or bubble in the wash. |
