Thread Number: 42432
Maytag A806 Won't stop filling cold water! |
Post# 624277   9/11/2012 at 18:58 (4,237 days old) by marks (Tucker, GA)   |   | |
Post# 624283 , Reply# 1   9/11/2012 at 19:33 (4,237 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 624288 , Reply# 2   9/11/2012 at 19:55 (4,237 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
If the water keeps coming in when you unplug the washer, the water valve is bad, no two ways about it. This is a very easy repair on a Maytag, it's done from the back.
Ken D. |
Post# 624464 , Reply# 3   9/12/2012 at 13:47 (4,236 days old) by Tomturbomatic (Beltsville, MD)   |   | |
If water keeps coming into the washer even with the water shut off, the A stands for "artesian" and the model would fetch big bucks in drought stricken areas. |
Post# 624495 , Reply# 4   9/12/2012 at 16:01 (4,236 days old) by marks (Tucker, GA)   |   | |
Post# 624505 , Reply# 5   9/12/2012 at 16:47 (4,236 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 624629 , Reply# 7   9/13/2012 at 07:16 (4,235 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It depends on the age of the washer and the valve in it. there could be one of at least 5 different inlet valves used on 806 MTs over their production years. Yes some are rebuild-able, but some like the Singer built valves you cannot get any parts for and if it has already been replaced with one of the newer vibration welded together valves you cannot even dissemble it without cutting it into pieces, LOL. I would never waste my time trying to repair a valve that can be had new for as little as $10 and risk another flood or the possibility of other leaks.
On older NLA designs I will rebuild them in a minute. |
