Thread Number: 42547
Maytag Washer and Dryer model number differences? |
Post# 626038   9/19/2012 at 01:06 (4,229 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
I found a matched pair of Maytag W&D's, while trying to find a Whirlpool Super Capacity Clean Touch 9 cycle/3 Speed A9700 or A9700s. They are as though they came off the assembly line...came with the house a young couple bought from a lady who was moving to an assisted living lifestyle.
They are: Model LA482 Washer/ LDE482 Dryer -electric Nice one page brochure from Thread 25864(www.automaticwasher.org/cgi-bin/T...) shows my washers, but ...is there any difference between the model numbers that begin with "LA" vs. the ones that being with only "A" letters? Did the LA482's preceed the A482? I did a search based on my serial numbers and found they were built in July/Aug 1984 (washer/dryer respectively). Someone in this group asked about their year of manufacture and their A482 was 1987. So I'm wondering if there were any differences with production runs with LA482 and the A482? I know the orbital trans came later, in 1988? Is it typical to find an electrical schematic in the consoles of these machines? I opened the dryer console, thinking that's what I needed to do, to open the front to clean it...and found a two-sided electrical wiring diagram and (reverse side) a Ladder Diagram. The model number is DE482, not LDE482. Model number conventions are so krptic. :-) Anyway I have that if anyone wants a copy. But I have no manual - so we are just using the washer and dryer, not knowing what hidden, if any, operations might be of help...or maybe not hidden. These are simple appliances, but someone probably knows about the hidden or lesser known features that may be there(?). Or I've inhaled too much lint. One thing I noticed about the overall construction, if you look at how the cabinet top lines up with the front vertical panel that is typically removed for servicing...they don't line up at even 90 degrees. The tops on both washer and dryer are staggered back about 1/2" or less(didn't measure) from their fronts. (see posted photo). Gadget Gary posted a Maytag brochure (Thread # 37095 found at: www.automaticwasher.org/cgi-bin/T... ) and the washer and dryer cases are all 90 degrees, top to sides and front. So, is there something off in construction or assembly on my units or did the orbital models have a corrected case alignment and mine is normal? Lastly, I noticed a number of cutouts on the dryer panel that will accomodate the other switches for higher end models. Has anyone replaced a panel from a higher end model and created, essentially, those added features or ...(more laboriously)...actually gone ahead and put in extra switches to get added features. This is now referred to as "PIMP MY DRYer or WASHer". :-) I sure would like a light inside the dryer - my mom had one on her old mid-60's models. With Fed regulations choking off the water supplies and temperature limits, I know it's not a priority. Some later Maytags(post 1987 orbital models? ) had a dryer light? Sorry for the long post. Alot to read on this website, but searching, I didn't see answers to my questions. Thanks for your comments, if any. CLICK HERE TO GO TO ovrphil's LINK |
Post# 626080 , Reply# 1   9/19/2012 at 07:45 (4,229 days old) by repair-man (Pittsburgh PA)   |   | |
A482 is a white machine and LA482 is almond. |
Post# 626085 , Reply# 2   9/19/2012 at 08:56 (4,229 days old) by cadman (Cedar Falls, IA)   |   | |
Post# 626090 , Reply# 3   9/19/2012 at 09:37 (4,229 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
So the "L" prefixes the color! That answers alot - thank you REPAIRMAN.
Honestly, these machines don't look used much at all - little eery, like someone used them and stored them for the rest of their 28 years. With the front cover off, the lint was just a light dusting - some soft paper or lint-free towel and a little vacuuming removed scant pieces of surface attached lint or dirt. Repairmen would be able to appreciate the lightly used condition, since they've seen it all. I only cleaned what I could from the portal in the back, vs. taking it apart. They aren't fancy, but as you guys here say, they're our "daily driver" for now. It's hard to look at these without being in awe of their condition...if only we aged as well, eh? :-) So while they're pretty much "as new", and don't appear to have been used hardly at all, time must affect the internals somewhere. Did these Maytags have any maintenance schedules suggested at 5 or 10 year intervals? I know there are people who own these and have never needed any service, but I know people who will run a car into the ground, not changing the oil, water, and other lubricants, too! Thanks all. |
Post# 626125 , Reply# 4   9/19/2012 at 13:13 (4,229 days old) by Kenmore71 (Minneapolis, MN)   |   | |
The machines that you found were special series machines that Maytag produced for certain "big box" stores in the 1980s and into the early 1990s. The features on that washer are basically identical to the A512 except that the A512 had an infinite water level and the A482 had a 4 position water level selector. If you post the last two LETTERS of the serial number of both the washer and the dryer we can date it to the year and month of production.
As far as preventative maintenance on Maytags I don't really think that there is any required on a pair of machines that seem to have been used so little. Might not be a bad idea to replace the belts on the washing machine since they may have hardened and developed flat spots if it really did sit unused for a long period of time. The same thing goes for the dryer belt. The long, thin belts in these dryers also get stiff and develop flat spots where they sit on the motor pulley and tensioner. In fact, I wouldn't be at all surprised if that belt breaks in the next 6 months now that it's being used regularly. This post was last edited 09/19/2012 at 14:13 |
Post# 626131 , Reply# 5   9/19/2012 at 13:48 (4,229 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Washer is serial 257671NN and Dryer is 344709NP
A special series..interesting, how do you guys know such minutia? I like it. It's our anniversary today, so special works for us. Infinite water level must mean,variable to whatever one wants to select? Infinite sounds like a child control is needed. :-[) I know the image sucks, but there they are. |
Post# 626138 , Reply# 6   9/19/2012 at 14:16 (4,229 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 626172 , Reply# 7   9/19/2012 at 19:08 (4,229 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
July/Aug 1984 - started my first "real" job in 1984, and "Against All Odds" by Phil Collins was playing.
I agree, I think I should replace the belts- found a link on the web(any best sources for parts?) Thanks Mark. If anyone has any ideas about the way the top and front aligns - I don't think I can do much about it, since the clips align with the top...how to move it forward to the edge? (yeah, picky,picky, picky) |
Post# 626180 , Reply# 8   9/19/2012 at 19:42 (4,229 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 626183 , Reply# 9   9/19/2012 at 19:51 (4,229 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
"If anyone has any ideas about the way the top and front aligns - I don't think I can do much about it, since the clips align with the top...how to move it forward to the edge? (yeah, picky,picky, picky)"
They're designed that way, as DADoES pointed out. Welcome to the sometimes wacky world of Maytag. |
Post# 626199 , Reply# 10   9/19/2012 at 21:48 (4,229 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
I remember a button, for the older guys who remember the wacky sixties, that said, "I don't want to be Normal". Maybe Maytag designers just had some of that philosophy and offset the top & front. I can sleep now.
That agitator reminds me of many of the Estes rockets I built in the mid 60's from kits....the piece that is the nose cone, as I call it, not the lint filter, is supposedly for dispensing softener....but is it also a dispenser for bleach at some cycle point? Thanks for the feedback, DaDoes and danemodsandy....really appreciate this group and site. |
Post# 626273 , Reply# 12   9/20/2012 at 06:43 (4,228 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Your machine has two dispensers.
One is the fabric softener dispenser, which as you know, is the cup on top of the agitator. It is NOT to be used for bleach; it works on a centrifugal-force principle and would fling undiluted bleach onto your clothes. The other dispenser is the detergent dispenser; it's the hollow center of the agitator's column. You put the measured amount of detergent in it, put the softener cup on top of the agitator, and then fill that. This feature was touted in early "New Generation" Maytag literature and manuals, but de-emphasized in later years. Your model does not have a bleach dispenser; if it did, it would be a triangular cup located on the left-hand side of the tub opening. You will need to add bleach manually, meaning that you should dilute a measured amount of bleach in about a quart of water and pour it in once the machine has finished filling and begun to agitate. It is not really possible to add a bleach dispenser; the cabinet top would need the requisite cut-out to accommodate the bleach cup, and the outer tub would have to have the cut-out needed for the inlet tube. Oh, you could do it with parts from a donor machine, but it would be major, major surgery - and a donor machine's parts are not jolly likely to be as pristine as your machines' existing parts are. |
Post# 626317 , Reply# 13   9/20/2012 at 11:18 (4,228 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
That's cool, I can add detergent into the agitator - was adding detergent at filltime(sans clothes)with a 7th gen. liquid detergent.
LOL! Adding Clorox bleach to the softener dispenser - maybe for a random tye dye shirts? Ok on the ratio..I was using Clorox Stain Fighter and Color Booster with detergent. A bleach dispenser would be nice, but this is just my raison d'tre to add/upgrade to a TOL'er. Just curious - haven't tried the delicate cycle, but what can I expect in operation? Is it supposed to start and stop through any chosen minute settings? Seems like someone mentioned that to me. Thanks guys, appreciate all your help/knowledge. |
Post# 626368 , Reply# 14   9/20/2012 at 15:41 (4,228 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Depends on whether your machine is a two-speed machine or a one-speed machine.
If it's two-speed, Delicate will wash at a lower speed than your other cycles. If it's one-speed, the Delicate cycle is something that Maytag called "Fabric-Matic." With Fabric-Matic, the washer agitates for a very short time, stops, lets the clothes soak a bit, then agitates again, then stops again, and so on until the end of the cycle. There are those who say Fabric-Matic is harsher on clothes than the Delicate cycle of a two-speed machine, but I have had a one-speed machine, and I did not find Fabric-Matic to cause any damage or undue wear and tear. |
Post# 626446 , Reply# 15   9/20/2012 at 21:58 (4,228 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 626475 , Reply# 16   9/20/2012 at 23:43 (4,227 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
This modest washer IS a Fabric-Matic. Who knows if it's a one speed, just because Maytag identified it as such? They could and did anything with their appliances. I'll get some delicates in there tomorrow and observe. One speed , two speed...sounds like the two speed motor was for the mid to top of the line models, for the various features.
These pair I found remind of my mom and dad, who took so good care of everything they bought(lost a house and car during the Depression). My mom had three washers and two dryers, total, from the 1940's til she passed in 1997. My sister finally had to replace my mom's early 1970 Frigidaire harvest gold stove, two years ago...close to 40 years of use for a mid-level product. That lady is a celebrity, but not too hopeful on delivering the message, tecnopolis. LOL! Good humor and true tribute deserved! |
Post# 626485 , Reply# 17   9/21/2012 at 00:54 (4,227 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 626583 , Reply# 18   9/21/2012 at 14:32 (4,227 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Thanks Ganksky1...I like the recessed supply valve alot, too!
So I have a one speed, danemodsandy...what's the deal with a two speed, is it just for the higher end machines? Just in case someone wants to compare, or yadayadawhatever.... Delicate load, small, warm/cold(was doing sox and underwear for the test)...here, in chronological order of functions (no drum roll, but coffee might help): 2 min fill 1 min soak 1 min agitate 4 min soak 2 min. agitate 1 min soak ~1 min-agitate 1 min -spins and extrudes water 4 min - final spin to dry clothes I estimated 15-17 min, but my numbers are rounded or off by the two or three times I stopped to adjust the load, being so light, to get a balanced spin. I don't see how the above process would be hard on delicates and if they're really delicate, I think I'd just hand wash them, if not to difficult. Cheers! |
Post# 626596 , Reply# 19   9/21/2012 at 15:41 (4,227 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
My first Maytag washer was an LA206, a one-speed machine with Fabric-Matic. My current Maytag washer is an LA806, a two-speed machine. You're right that as you go up the model line, you get the two-speed feature.
I am very happy to have an LA806, trust me. But the LA206 could basically do everything the 806 can, with maybe just a tiny bit less flexibility. At the time I had the LA206 with Fabric-Matic, my late partner was ill with end-stage heart failure, and had to wear compression stockings. Compression stockings can easily be ruined by washing them harshly; the get full of runs and won't maintain compression any more. I never damaged a single compression stocking in the LA208. Not one. I used the Fabric-Matic Delicate cycle, and a lingerie bag, and never had a moment's problem. The LA806 uses a low speed for the Delicate cycle, and has also never damaged anything. It also has a "Gentle Spin" option for the spin cycle if something's really delicate, which is something impossible to do with a one-speed machine, of course. The other differences in the 806 machine are: More water levels (4), more wash/rinse temperature combinations and cycle options for Soak and Pre-Wash. Of the two machines, I consider the 806 to be a wonderful machine with the best of everything, of course. But the 206 was the more elegantly engineered of the two, giving nearly the same level of performance as the 806 with simpler mechanicals. The 206 was just one model off the bottom-of-the-line, yet you got that Delicate cycle, a bleach dispenser, a detergent dispenser and a softener dispenser. You didn't get that many features on some competing brands until you got at least halfway up the line, maybe higher. And competing brands often used more complex mechanicals that broke down more often, Kenmore's dispenser was a real problem in that regard. Did I mention I kind of like Maytags? ;) |
Post# 626619 , Reply# 20   9/21/2012 at 17:14 (4,227 days old) by qsd-dan (West)   |   | |
Post# 626624 , Reply# 21   9/21/2012 at 17:25 (4,227 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 626625 , Reply# 22   9/21/2012 at 17:27 (4,227 days old) by Kenmore71 (Minneapolis, MN)   |   | |
To my knowledge there never was a LA206 manufactured. The A206 was made from 1966 to 1972 and was a two speed machine with a standard (16 gal.) sized tub. I don't think the A206 was not offered in decorator colors initially. It was replaced with the A207 in 1973 which was also a 2 speed, standard tub machine. Almond (the "L" prefix before the "A") was first offered around 1977.
In the center dial "wash-power automatic" line (1966-1980), the A106, A107 & A108 were one-speed standard capacity machines, the A206, A207 & A208 were 2-speed standard capacity, the A406, A407 & A408 were the large-tub (19 gal) single-speed and the A606, A608, A808 & A906 were the 2-speed large-tub machines. The color prefixes were as follows: T = Turquoise (1966 & part of 1967) Y = Castillian Yellow (1966 until about 1968) C = Cordoba Copper (1966 until 1976) V = Shaded Spanish Avacado (1967 until 1976, replaced turquoise) H = Harvest Gold (1968 until 1976, replaced yellow) In 1977 all appliances lost their shading and Almond ("L" prefix) was added |
Post# 626640 , Reply# 23   9/21/2012 at 18:16 (4,227 days old) by qsd-dan (West)   |   | |
Post# 626651 , Reply# 24   9/21/2012 at 19:38 (4,227 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Love the info. I was getting lost from A206 into A208...mutations? whazzuh? Started talking to myself: " ... you guys ..talk among yourselves...". LOL!
18 days straight? You sound like my bro-in-law; they don't have enough workers and the guys keep quitting, so he is constantly training new hirees..works weeks w/o a day off. Looking at your A108 and dryer(very NICE), reminded me of this from Craigslist today(link attached). Did it come in shell pink? (I think it would be a perfect color for that model. The Wash-Power Automatic line (thanks , Mark, was wondering if MT had a name for this successful line) had zen-like clean lines. It's all a matter of taste, of course, but simplicity speaks volumes, as Apple, Inc. has shown. Yes, your A806 sounds like you could hold on to it for-everrrr. Now, what's an A906, that Dan has in his collection? I just need to get comfortable with operation my humble set. Thanks all. CLICK HERE TO GO TO ovrphil's LINK on Atlanta Craigslist |
Post# 626652 , Reply# 25   9/21/2012 at 19:48 (4,227 days old) by qsd-dan (West)   |   | |
Post# 626654 , Reply# 26   9/21/2012 at 19:54 (4,227 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Do NOT mention 906s! I dream about those babies! And they are so rare, I will most likely never even see a pair in the flesh, let alone possess a set! WAAAAAAAAAAAH!
In the absence of 906s, I hope my 806 pair lasts me forever. They are actually more versatile than 906s, which offered no cycle modifications, but are less space-age, push-button gorgeous. They're extremely capable machines. I'm not kidding about 906s, though. I don't even think I should be looking at a pair if it wasn't for sale, because the visit would probably end with the local constabulary prying me off the pushbuttons! ;-) |
Post# 626656 , Reply# 27   9/21/2012 at 20:01 (4,227 days old) by qsd-dan (West)   |   | |
Post# 626657 , Reply# 28   9/21/2012 at 20:06 (4,227 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 626662 , Reply# 29   9/21/2012 at 20:14 (4,227 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 626663 , Reply# 30   9/21/2012 at 20:15 (4,227 days old) by qsd-dan (West)   |   | |
Post# 626665 , Reply# 31   9/21/2012 at 20:22 (4,227 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
"Lots of patients and persistence will eventually land you a set of your very own"
You don't understand. I live close to both Ben Swestka (swestoyz) and Cory Heisterkamp (cadman). The mighty mojo of those two is too much to compete with, LOL! They both regularly find stuff I don't even dare dream about. ;-) |
Post# 626670 , Reply# 32   9/21/2012 at 20:56 (4,227 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
came across this when it first "aired" and this set is why I remember the color pink being offered..
what do you think, nice? Being from Michigan...gotta check out that Maytag Musem in Benton Harbor. If the link doesn't work, here's another: www.newson6.com/Global/story.aspQ... Someone in this group probably owns a set - could it be they got the winning bid that day: http://frankiezwife.blogspot.com/2010/10... CLICK HERE TO GO TO ovrphil's LINK |
Post# 626678 , Reply# 33   9/21/2012 at 22:00 (4,227 days old) by qsd-dan (West)   |   | |
PA700/PDE701
I remember when that aired a few years back.
There's a nice DE700 near me, but I'm out of room. Maybe someone nearby will be interested. CLICK HERE TO GO TO qsd-dan's LINK on Stockton Craigslist |
Post# 626713 , Reply# 34   9/22/2012 at 01:22 (4,226 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Here's a nice starter set, reasonably priced for the apparent new condition they appear to be in. I doubt they will be up for sale long.
CLICK HERE TO GO TO tecnopolis's LINK on Ocala Craigslist |
Post# 626737 , Reply# 35   9/22/2012 at 08:10 (4,226 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 626741 , Reply# 36   9/22/2012 at 08:29 (4,226 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
I nearly missed the best photos on this thread..and the table of Standard Line Maytags...
A906's - no wonder they are a source of envy and "wanton lust"- lol. Kenmore71 - it's interesting, that Maytag produced that A806 for such a long time- 1966 to 1980,but stopped producing A906's in 1972. The A806's were probably more refined, with so many years running? y/n? And in 1980, it's also interesting that part of the year, they ran the last of the existing products and changed over to the A*10 product line. Any known improvements? I remember looking for work in 1981 - really a bad economic slump..wonder if those machines were adjusted for the economy or anticipated better times? I mean, just wondering how they "sized up" in quality, features, etc. to the previous 14 yrs of products, generally speaking? A906's. I had to ask. "Don't Look Ethel!...too late, he was incensed with A906's". |
Post# 626762 , Reply# 37   9/22/2012 at 09:42 (4,226 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 626782 , Reply# 38   9/22/2012 at 11:40 (4,226 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
My dryer works fine, but when I removed the front to clean lint, I saw a part laying in the right corner. I didn't hear anything drop, over the noise of swinging and dropping off the face, but this is first time I opened a dryer up.
It looks like a fastener. I did try and locate, using the Maytag provided Repair Part List - LA482.pdf, but my I couldn't see it. Also, I didn't see another one being used inside. Anyone - have you seen this part in a Maytag dryer like or similar to the LA482? I figure it's just a loose part.... ? ? ? Thank you! |
Post# 626841 , Reply# 39   9/22/2012 at 15:18 (4,226 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 626954 , Reply# 40   9/22/2012 at 22:17 (4,226 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
