Thread Number: 42764
1980's GE Filter Flo only Spins on slow speed? |
Post# 628999 , Reply# 1   10/2/2012 at 14:34 (4,195 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 629007 , Reply# 3   10/2/2012 at 15:19 (4,195 days old) by Yogitunes (New Jersey)   |   | |
If your not worried about the slow speed....I would either disconnect, or remove the solenoid actuator.....high speed all the time.....
unless....there is something wrong with the clutch, could be the two arms that fly out for the higher engagement are stuck....but then again, you do get high speed agitation, so that would probably rule this out...just something to be on the lookout for should you remove the solenoid, and still get slow speed..... yeah, those single speed clutches KICK ASS for agitation and spin.... let us know how you make out..... |
Post# 629015 , Reply# 4   10/2/2012 at 16:38 (4,195 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
keepitclean, Having just gone through what you are describing. I'll give you a few things to check to verify the position of your clutch during operation.
**The GE workshop manual specifically states DO NOT switch speeds with the motor engaged** 1) All muti-speed GE flo's start out in gentle, then switch to regular agitate. 2) If your machine starts out in regular fast or won't engage gentle, your solenoid is not getting power or jammed. The default speed is regular if there isn't any interaction from the actuator arm. 3) This last one is the hardest. Get a very bright flashlight and verify the position of the speed actuator arm. If it's down and not making any contact with the clutch cams, you should have normal/fast. If it's in the up position with it's paw holding one of the 2 clutch cams, you're in gentle. If you have it switched to Normal/fast and the cam is still up, you either have a short in the wiring keeping the solenoid energized or the cam arm is sticky/bent to far upwards and isn't comming down low enough to clear the spinning clutch cams. (Which was what happened to me when a leak energized the actuator during the wrong time, bending the arm, I took a long screwdriver and rebent the arm back down to clear the clutch cams and restarted the machine with normal back in biz. |
Post# 629017 , Reply# 5   10/2/2012 at 16:40 (4,195 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 629020 , Reply# 6   10/2/2012 at 16:48 (4,195 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
