Thread Number: 42794
KDS-19 leak |
Post# 631323 , Reply# 5   10/13/2012 at 15:33 (4,212 days old) by blanchem ()   |   | |
No advice on the door removal question? Can the door of a KDS-19 be removed without disconnecting and removing the dishwasher from under the counter? |
Post# 631354 , Reply# 6   10/13/2012 at 17:30 (4,211 days old) by rp2813 (Sannazay)   |   | |
I'm pretty sure you can remove the door without pulling the whole machine out from under the counter, in fact I'd recommend it since the whole machine won't tip forward when you have the door open. It's much easier to get the door back on if you have a second person to help you line up the holes for the hinges.
Just to confirm -- the clips Steve mentioned are part of the bottom rack assembly. They clip to the rack at the front on both corners.
I've attached a picture. This is on a model slightly later than yours, but the clips would be the same. |
Post# 631421 , Reply# 9   10/13/2012 at 23:30 (4,211 days old) by rp2813 (Sannazay)   |   | |
Post# 631908 , Reply# 12   10/15/2012 at 18:56 (4,209 days old) by pdub (Portland, Oregon)   |   | |
