Thread Number: 42810
Calling Stevet calling stevet KDP-20 acting up! |
Post# 629517   10/5/2012 at 03:00 (4,213 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Hey Stevet: almost done restoring my KDP-20 but I have found a problem with the bimetal motor on the pre-wash door. It doesn't open. I have removed the doors cleaned the shafts and installed new o-rings. The wash door SNAPS open. I notice the pre-wash door is wired through the rinse aid dispenser and the wash door is not.
How do these bimetal things work, I tried removing it and applying power directly to the bimetal and it shorted the circuit breaker. signed- Confused in Boston. jon |
Post# 629541 , Reply# 1   10/5/2012 at 05:35 (4,213 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Calling Dr. Bombay. Calling Dr. Bombay. Please come in. We need you right away. |
Post# 629709 , Reply# 2   10/5/2012 at 19:30 (4,212 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 629790 , Reply# 3   10/6/2012 at 08:00 (4,212 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 629810 , Reply# 4   10/6/2012 at 10:55 (4,212 days old) by appnut (TX)   |   | |
Post# 629817 , Reply# 5   10/6/2012 at 11:36 (4,212 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 629824 , Reply# 6   10/6/2012 at 12:17 (4,212 days old) by fnelson487 (Palm Springs, CA)   |   | |
Post# 629999 , Reply# 7   10/7/2012 at 10:47 (4,211 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 630116 , Reply# 9   10/7/2012 at 21:17 (4,210 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 630120 , Reply# 10   10/7/2012 at 21:20 (4,210 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 630214 , Reply# 12   10/8/2012 at 11:13 (4,210 days old) by bajaespuma (Connecticut)   |   | |
Post# 630218 , Reply# 13   10/8/2012 at 11:27 (4,210 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Adding a posting moves (bumps) the thread back up to the top of the pile so it is more easily seen. |
