Thread Number: 42832
Why did Maytag use the Gulmite bolt heads? |
Post# 629914   10/6/2012 at 22:38 (4,212 days old) by scoots (Chattanooga TN)   |   | |
Does anybody know why Maytag used the odd ball Gulmite Bolt heads to secure the tub to the power unit in their wringer washers? The Gulmite heads look like they'd be easily fouled, not to mention it looks like they amount of torque they'd transmit was limited before they rounded off.
I assume Maytag used them to keep home owners "out of the machine" so that service calls were mandatory. |
Post# 629919 , Reply# 1   10/6/2012 at 23:12 (4,212 days old) by stan (Napa CA)   |   | |
Post# 629921 , Reply# 2   10/6/2012 at 23:17 (4,212 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 629938 , Reply# 3   10/7/2012 at 00:34 (4,212 days old) by qsd-dan (West)   |   | |
Post# 629997 , Reply# 4   10/7/2012 at 10:44 (4,212 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Gulmite bolts. Patented in the mid thirties, they were developed for aircraft, as light aluminum, tamper proof and vibration proof fasteners with a low profile . With the correct tool they can be torqued very high but will strip if you don't have a set of gulmite wrenches.
So yes they did provide servicemen with a "key" only they had to work on your machine, just like the later tub bolts used in the automatics, Maytag, Frigidaire & Kenmore included. But also they provide a snag free design when dealing with clothing and were used extensively on the door areas of Bendix machines for this reason. I have never fooled around with Maytag wringers so you can tell me do the bolt heads appear anywhere near the tub and clothing areas? Ahem! Some members living in or near St Paul, have replaced their Gulmite bolts with six sided standard bolts. Tsk Tsk! Also used extensively on school buses! They were the first tamper proof fastener. This post was last edited 10/07/2012 at 15:50 |
