Thread Number: 42895
A806 not completing cycle, leaking from under center |
Post# 630857 , Reply# 1   10/11/2012 at 11:44 (4,212 days old) by eedel ()   |   | |
Note: this is only happening on permanent press mode, running a timed cycle results in no leaks and no stoppage. |
Post# 630862 , Reply# 2   10/11/2012 at 12:08 (4,212 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Are you saying that the timer stops advancing or that the wash action stops? |
Post# 630864 , Reply# 3   10/11/2012 at 12:21 (4,212 days old) by eedel ()   |   | |
Both, everything stops but the light stays on |
Post# 630868 , Reply# 5   10/11/2012 at 12:54 (4,212 days old) by Kenmore71 (Minneapolis, MN)   |   | |
This is a very strange set of circumstances.
At what point in the Permanent Press cycle does it stop? Is it during the wash phase, the cool-down phase or the rinse phase? If I read correctly it only leaks on the Permanent Press cycle? I cannot for the life of me think of a reason why it would leak on one cycle and not another. |
Post# 630882 , Reply# 6   10/11/2012 at 14:10 (4,212 days old) by eedel ()   |   | |
It completes its initial fill and wash (agitator moves) then stops. Don't get the leaking myself, I'm stumped as to it working fine one way and leaking the other |
Post# 630883 , Reply# 7   10/11/2012 at 14:12 (4,212 days old) by eedel ()   |   | |
Starting to think its 2 independent problems with wierd coincidence |
